When you report back to us reading everything below “What can you do?” please answer us
- What device do you use and are your drivers up to date?
- Please tell us your capture or playback settings?
- What have you tried so far?
What can you do?
Make sure drivers are updated.
Check your default Capture and Playback devices
Especially for Windows 8.1 and newer > Check your default Communication devices. -
Try to select your device directly and not default under
TS3 : Tools > Options > Playback or Capture.
TS5: Options > Audio -
TS3: Is there a capture or playback profile set in your bookmark?
Please check your settings under Bookmarks > Manage Bookmarks > Click on “Go Advanced” -
Are these the right profiles? Compare them with these from your settings.
On Windows 10 after updating to version 1803 it is required that access to your microphone is enabled.
These 2 settings must be enabled:
Microphone access for this device
Allow apps to access your microphoneThe settings can be found under Settings -> Privacy -> Microphone (left side)
You can also press Windows key + R and type in ms-settings:privacy-microphone to reach that setting. -
On Mac Os you must make sure access to the microphone is granted before you can use it.
Try to sending something with Push-To-Talk/Continuous Transmissions enabled.
Is the slider in your capture profile set to high? Test and move it in the local test mode.
Are you sure, that you channel isn’t moderated and or you have enough talk power to speak in it?
Check that the channel isn’t in silence mode. This happens when a lot users (differs from server server to server via server setting) are in channel.
Is the user you can not hear muted?
Did your turn down the volume? Open Tools -> Options -> Playback and turn the Voice Volume Adjustment slider up.
Is the client muted in the Windows volume mixer? Do a right-click on the speaker icon in your tray and then select Open Mixer to check this
Don’t forget that some devices also have mute function and you may muted your microphone there.
