Where do I place my License key?
I purchased a license for my TS Server! how do I put the license into my server?
Put the licensekey.dat it in root folder of the server. Then start the server.
Also make sure that server can reach accounting.
Where should I put it?? freely?
This is not a license key.
It’s the software license agreement.
these files I own in the server
Put your license key inside teamspeak folder.
When you purchased a license, then a licensekey.dat file is send to you.
This licensekey.dat is needed.
Needs to be with the server files (same folder you posted on your screenshot)
The correct license file name is licensekey.dat
Make sure the inside of licensekey.dat contains both license and license2 blocks.
So, I have two questions here, because I haven’t been able to make this work. I recently bought a Gaming license for my self-hosted Teamspeak server. However, the instructions said to upload it to the root of the teamspeak user. So, for Ubuntu22.04LTS, would I upload this to /home/teamspeak, or /home/teamspeak3-server_linux_amd64 directory? The other question that I have is do I have to do anything to the licensekey.dat file, for example, make it exicutable? The third question, that I’m thinging about, so I’ll ask while I still remember. it says it can’t find a .ini file. I made one in my /home/teamspeak/teamspeak3-server_linux_amd64 directory. Hopefully, that will work. And finally, would anybody know the best way to view my log file for the teamspeak server? I ask, because I didn’t my account query information, so couldn’t write it down. Any help would be appreciated.
I don’t know if I mentioned this in the post, but I am hosting this server on Ubuntu22.04LTS
Your licenskey.dat need to be in the directory from where youre starting your server (where the .sh is located to start)
Logs you can find in the /logs directory which is also located in the main directory of the server. In linux you can see you logs with
cat /logs/<logfileName>.log
.. if youre in the server main directory
