The Windows client assigns itself an integrity level during startup of S-1-16-8208
. The RID (actual integrity level) of this in hex is 0x2010, and the most similar well-known integrity level is 0x2100 (Medium-Plus). Because of this similarity, I suspect it was merely a typo, and it still behaves as expected, however is still technically undocumented, as nowhere in the Windows documentation does it state that the integrity level RID can be an arbitrary integer.
The value isn’t set manually, the base value is modified by ‘UIAccess’ being enabled. That’s for the context of global hotkey support in games.
That is why, given a specific game, hotkeys may work if TS is installed in Program Files, but not on e.g. C:\portable\ts - for this elevation to be of effect, installation in a secure location is required (unless windows is configured otherwise).
