Teamspeak Build number 1737468425
I am using a Corsair Virtuoso RGB Wireless headset (connected via the USB dongle) on Windows 11. If I reconnect after losing connection (e.g., leaving and returning to a connected area), Spotify automatically resumes playback.
However, in Teamspeak 6.0.0 Beta 2, my headset gets disabled, and I have to go into the settings, select a different audio device, and then reselect the wireless headset to make it work again.
This issue occurs regardless of whether my headset is set as the default device in Windows or if it is manually selected in Teamspeak. It does not happen in other applications—only in Teamspeak.
Is this a known issue, and is there a possible fix for it?
