403 when contacting accounting2
Except the TS3ANetwork error i see that it shows up every 10 minutes which is the weblist and it’s down and you can ignore it, I see that your server can’t communicate with the accounting system (since you have an active license). Make sure that you have opened all the required ports:
can you help me with that, I tried something but it didn’t work and I still can’t find a solution
what should I do to change those ports?
Since you have Ubuntu this tutorial about setting up firewall rules will help you for sure.
I did everything needed for those ports, however when reinstalling the vps I didn’t insert the ts3 license and the server didn’t shut down even once, I also got the error ā€œTS3ANetwork::Send failed error: 111ā€ but it didn’t shut down , when I put in the ā€œnon-profit licenseā€ my server shut down after 2 hours and every time it shuts down after 2 hours when the license is present
same 0.log as above
2022-12-03 16:24:07.849818|ERROR   |Accounting    |   |Server https://accounting2.teamspeak.com replied with status: 403 Forbidden
2022-12-03 16:24:07.871796|ERROR   |Accounting    |   |Error contacting server https://backupaccounting2.teamspeak.com: RESOLVE_ERROR: Host not found (authoritative)
2022-12-03 16:24:07.871850|ERROR   |Accounting    |   |Unable to connect to accounting server
It could be that Cloudflare thinks that your server ip is suspicious.
https://support.cloudflare.com/hc/en…-site-visitor-
You can test your IP on Inspect an IP | Project Honey Pot
The Project Honey Pot system has detected behavior from the IP address consistent with that of a spam harvester and comment spammer . Below we’ve reported some other data associated with this IP. This interrelated data helps map spammers’ networks and aids in law enforcement efforts. If you know something about this IP, please [leave a comment]
what I can to do now
If the problem is ip as you say or those ports,
how does it work for me no problem a server that has no license means it has 32 slots until i insert my license, and when I insert my ā€œnon-profit licenseā€ license, the server shuts down for exactly 2 hours of work .
And i get this error
Without license there is no need to contact accounting.
https://www.projecthoneypot.org/contact_us.php?ft=Mistaken%20Listing
