Windows/Android for the client, Linux for the server
Yes, I run a private server for a gaming group
About a 4
Better handling of audio device changes and simplified audio configuration. Users often get confused when they can’t hear or speak because they’re using a different audio device that needs different levels.
Overall, how long have you used TeamSpeak for? (any version)
For 7 years and 3 days exactly.
What OS/OS’s are you currently using?
Windows 10, though my installation is kinda messed up.
Are you currently a server owner, an active user (but don’t run your own server), inactive, or a mixture of the prior?
I am a server owner through a provider and a user both since 2014.
On a scale of 1-5 (1 being low and 5 being the best), how would you score your technical knowledge on TS?
4-5
Optional question - If you could add something that doesn’t exist on TS currently, what would it be and why?
Dedicated and Serverwide Text and Image only channels.
Since 2016
Windows 10
I am an active user
I’d describe it as a 3
I would add a way to send messages to people even though they are on a different server, because it’s very convenient for communicating.
I’ve been using TeamSpeak for about 6 years now (since 2015 I believe).
Currently, I’m using TS on Windows 10 as an active user and I’m hosting my own server on Linux.
I’d rate my skills somewhere between 3 and 4.
My most wanted feature is screen sharing. I find it very useful when troubleshooting my friends’ technical problems.
Since 2012
Windows 10
Administrating Community Gaming and Ts
To be honest,i think 4 is good score for me
I think screen sharing will be cool for a group of people who want to see something in the same time
1. Overall, how long have you used TeamSpeak for? (any version)?
Since 2012
2. What OS/OS’s are you currently using?
Mainly Windows 10 but I occasionally use the Android version.
3. Are you currently a server owner, an active user (but don’t run your own server), inactive, or a mixture of the prior?
I run a server which has quite a basic setup and I am also a user.
1. On a scale of 1-5 (1 being low and 5 being the best), how would you score your technical knowledge on TS?
about 4
5. Optional question - If you could add something that doesn’t exist on TS currently, what would it be and why?
More integrations with other programs.
Hello! I would love to help with Alpha testing! 1. Overall, how long have you used TeamSpeak for? (any version)
Unable to pinpoint it exactly but its around 10 years. 2. What OS/OS’s are you currently using?
I am using MacOS Big Sur on my Macbook and Windows 10 for my PC. And Android and iOS on my phones. 3. Are you currently a server owner, an active user (but don’t run your own server), inactive, or a mixture of the prior?
I am co-administrator of a gaming community TS3-Server 4. On a scale of 1-5 (1 being low and 5 being the best), how would you score your technical knowledge on TS?
In regards to working with it on a server administrator level probably around 3- 4. I am very comfortable with setting up and configuring servers, but I assume there is always something new that I could learn. 5. Optional question - If you could add something that doesn’t exist on TS currently, what would it be and why?
Screensharing would be a great addition.
Overall, how long have you used TeamSpeak for? Since early 2016
What OS/OS’s are you currently using? Windows 10
Are you currently a server owner, an active user (but don’t run your own server), inactive, or a mixture of the prior? Server Owner
On a scale of 1-5 (1 being low and 5 being the best), how would you score your technical knowledge on TS? 3
Optional question - If you could add something that doesn’t exist on TS currently, what would it be and why? Being able to screen share with another user.
15 or so years
Windows 10
Server owner and active daily user
Probably between 4-5
Better server management within Teamspeak with an overhauled permission system
Really looking forward to the new Teamspeak, always loved Teamspeak, always will.
I am using Teamspeak for the last 6 Years i think.
Windows 10
I own a server with active useres online and use many different Teamspeak Servers on a daily basis
About 3
Text Channels that allows pictures to be posted
Hello, I would like to apply to be an Alpha Tester!
-For about 5 years
-Windows 10
-I am an active user and co-owner of a small community server
-Because I’ve only been using TeamSpeak for a long time, I would say 5
There should be features like screen sharing or video calling. There should also be more options for the “rooms”, e.g. profile pictures
