Bookmark / identity disapear from my pc (MyTeamspeak Connected)
08.09.2023 18:18:32 SB Debug onUpdateClientEvent: serverId = 1, clientId = 33903, invokerID = 0, invokerName = , invokerUID =
08.09.2023 18:19:16 SB Debug onUpdateClientEvent: serverId = 1, clientId = 33903, invokerID = 0, invokerName = Server, invokerUID =
08.09.2023 18:19:18 SB Debug onUpdateClientEvent: serverId = 1, clientId = 33903, invokerID = 0, invokerName = Server, invokerUID =
08.09.2023 18:19:19 SB Debug onUpdateClientEvent: serverId = 1, clientId = 33903, invokerID = 0, invokerName = Server, invokerUID =
08.09.2023 18:19:21 SB Debug onUpdateClientEvent: serverId = 1, clientId = 33903, invokerID = 0, invokerName = Server, invokerUID =
08.09.2023 18:19:25 SB Debug onUpdateClientEvent: serverId = 1, clientId = 33903, invokerID = 0, invokerName = Server, invokerUID =
08.09.2023 18:19:34 SB Debug onUpdateClientEvent: serverId = 1, clientId = 33903, invokerID = 0, invokerName = Server, invokerUID =
08.09.2023 18:19:36 ProtobufRPC Warning Server at URL https://clientapi.myteamspeak.com/authentication responded: 503
08.09.2023 18:19:36 ClientUI Warning Account login failed, server currently not available. Retry in few minutes.
08.09.2023 18:19:36 SCHandler Info try to delete mytsid while no valid mytsid is set - abort
08.09.2023 18:19:36 SB Debug onUpdateClientEvent: serverId = 1, clientId = 33903, invokerID = 0, invokerName = , invokerUID =
08.09.2023 18:19:52 Info Memory usage: 144.68 MiB
08.09.2023 18:20:18 SB Debug onUpdateClientEvent: serverId = 1, clientId = 33510, invokerID = 0, invokerName = , invokerUID =
08.09.2023 18:22:42 SB Debug onUpdateClientEvent: serverId = 1, clientId = 33511, invokerID = 0, invokerName = , invokerUID =
08.09.2023 18:24:31 SB Debug onUpdateClientEvent: serverId = 1, clientId = 33510, invokerID = 0, invokerName = , invokerUID =
08.09.2023 18:25:14 SB Debug onUpdateClientEvent: serverId = 1, clientId = 33909, invokerID = 0, invokerName = , invokerUID =
08.09.2023 18:25:15 SB Debug onUpdateClientEvent: serverId = 1, clientId = 33909, invokerID = 0, invokerName = , invokerUID =
08.09.2023 18:25:40 ProtobufRPC Warning Server at URL https://clientapi.myteamspeak.com/authentication responded: 503
08.09.2023 18:25:40 ClientUI Warning Account login failed, server currently not available. Retry in few minutes.
08.09.2023 18:25:40 SCHandler Info try to delete mytsid while no valid mytsid is set - abort
08.09.2023 18:25:40 SB Debug onUpdateClientEvent: serverId = 1, clientId = 33903, invokerID = 0, invokerName = , invokerUID =
08.09.2023 18:25:44 ProtobufRPC Warning Server at URL https://clientapi.myteamspeak.com/authentication responded: 503
08.09.2023 18:25:44 ClientUI Warning Account login failed, server currently not available. Retry in few minutes.
08.09.2023 18:25:44 SCHandler Info try to delete mytsid while no valid mytsid is set - abort
08.09.2023 18:25:44 SB Debug onUpdateClientEvent: serverId = 1, clientId = 33903, invokerID = 0, invokerName = , invokerUID =
08.09.2023 18:26:58 ProtobufRPC Warning Server at URL https://clientapi.myteamspeak.com/authentication responded: 503
08.09.2023 18:26:58 ClientUI Warning Account login failed, server currently not available. Retry in few minutes.
08.09.2023 18:26:58 SCHandler Info try to delete mytsid while no valid mytsid is set - abort
08.09.2023 18:26:58 SB Debug onUpdateClientEvent: serverId = 1, clientId = 33903, invokerID = 0, invokerName = , invokerUID =
08.09.2023 18:27:43 SB Debug onUpdateClientEvent: serverId = 1, clientId = 33510, invokerID = 0, invokerName = , invokerUID =
08.09.2023 18:27:55 SB Debug onUpdateClientEvent: serverId = 1, clientId = 33510, invokerID = 0, invokerName = , invokerUID =
08.09.2023 18:28:57 SB Debug onUpdateClientEvent: serverId = 1, clientId = 33511, invokerID = 0, invokerName = , invokerUID =
08.09.2023 18:29:07 SB Debug onUpdateClientEvent: serverId = 1, clientId = 33511, invokerID = 0, invokerName = , invokerUID =
https://www.myteamspeak.com ist down :-/
We are publishing an update to myTS service. That’s why it is down.
Can you say how long MyTeamspeak will remain down for the update?
Sry I can’t say any timeframe at the moment.
@anyone. Please use English in this thread. Danke
Okay, the main thing is that it works again afterwards and the work on the update wasn’t in vain
The maintenance for today ist over.
We hope last users who had missing sync items now get them.
Please report back.
But I still have problems every now and then because the list isn’t displayed in the TS. Once everything is there, half of it is gone again… and after a few seconds it’s back again
on my part, the connection to myTS works, but the favorites are not yet back.
2023-09-09 05:04:34.991749|INFO    |ClientUI      |   |Qt version: 5.15.2
2023-09-09 05:04:34.991749|INFO    |ClientUI      |   |Using configuration location: C:\Users\xxxxx\AppData\Roaming\TS3Client\settings.db
2023-09-09 05:04:35.484209|INFO    |ClientUI      |   |Last update check was: sam. sept. 9 06:57:01 2023
2023-09-09 05:04:35.484209|INFO    |              |   |Statistics report: User previously denied participation
2023-09-09 05:04:35.484209|INFO    |Bookmarks     |   |Collecting autoconnect bookmarks
issue occurs, i start ts, everything looks normal, i go to “manage bookmarks” or even to “tools/options” for exaple, everything disappears.
  1. The bookmark manager still loads every once in a while
  2. Identifiers are always loaded (no problem anymore)
  3. subscription to channels does not expire
the problem with bookmarks remains
Tell me, is recruitment for Teamspeak 5 still going on? How long does it take to get approval?
After changing style,theme and iconpack to default, i can recover my bookmarks when i enter them, but it still keeps disappearing.
edit : will try reinstall once more.
edit2: its still acting weird even after reinstall, going to TOOLS and whatever there immediately blanks my bookmarks.
edit3: tried deleting and readding servers, since i only use like 4, but did not help
The sync error is gone.
The bookmark manager loads every once in a while.
If there are no bookmarks, open - “manage bookmarks” and close. The bookmarks will appear in the list.
If you repeat this operation, the bookmarks will disappear. :upside_down_face:
edit: Disappearing tabs is also available in mobile Voice Chat.
I have the same problem. Let’s hope they fix it today too
Same here, it´s gone again.
@TS.ChrisR Can we just import our saved identities until we get them re-synchronized or would that be problematic?
Never mind, restarted the client and now it is synchronized…
I still have another issue.
Since the changes to myteamspeak my client will lose all subscriptions to channels after 10 minutes
09.09.23 14:32:09		Info	TeamSpeak Client 3.6.1 (2023-07-24 10:06:33)
09.09.23 14:32:09		Info	SystemInformation: Linux 6.4.11-1-default #1 SMP PREEMPT_DYNAMIC Thu Aug 17 04:57:43 UTC 2023 (2a5b3f6) x86_64 Binary: 64bit
09.09.23 14:32:09	PulseAudio	Debug	connected to pulse audio server -
09.09.23 14:32:09	SoundDevManager	Debug	Loading dynamic soundbackend from /usr/libexec/teamspeak3-client/soundbackends/libalsa_linux_amd64.so
09.09.23 14:32:09	SoundDevManager	Debug	Soundbackend loaded.
09.09.23 14:32:09	ClientUI	Info	OpenGL Info: LibGL, Vendor: AMD, Renderer: AMD Radeon RX 6800 XT (navi21, LLVM 16.0.6, DRM 3.52, 6.4.11-1-default), Version: 4.6 (Compatibility Profile) Mesa 23.1.6
09.09.23 14:32:09	Addons	Info	Checking for addon updates...
09.09.23 14:32:09	Plugins	Info	Loading plugin: libclientquery_plugin_linux_amd64.so
09.09.23 14:32:09	Query	Info	listening on 127.0.0.1:25639
09.09.23 14:32:09	ClientUI	Info	Failed to init text to speech engine
09.09.23 14:32:09	ClientUI	Info	Qt version: 5.15.8
09.09.23 14:32:09	ClientUI	Info	Using configuration location: /home/[user]/.ts3client/settings.db
09.09.23 14:32:09	Addon	Info	Addon up to date.
09.09.23 14:32:09		Info	disconnected from push system.
09.09.23 14:32:09		Info	connected to push system.
09.09.23 14:32:09	Bookmarks	Info	Collecting autoconnect bookmarks
09.09.23 14:32:09	Bookmarks	Info	 + Meiner
09.09.23 14:32:09	ClientUI	Info	Connect to server: [ip]
09.09.23 14:32:09	ClientUI	Info	Initiating connection:  [ip]
09.09.23 14:32:09	ClientUI	Info	Last update check was: Sa. Sept. 9 16:29:22 2023
09.09.23 14:32:09		Info	Statistics report: First run, report later in 1-30 days
09.09.23 14:32:09		Info	Statistics report: Setting next report date to: Di. Sept. 26 16:32:09 2023
09.09.23 14:32:09	ClientUI	Info	Connect status: Connecting
09.09.23 14:32:09	PktHandler	Info	server sent ciphers:1
09.09.23 14:32:09	PktHandler	Info	Selected cipher:0
09.09.23 14:32:09	PktHandler	Devel	Puzzle solve time: 4
09.09.23 14:32:10	ClientUI	Info	Connect status: Connected
09.09.23 14:32:10	ClientUI	Info	Connect status: Establishing connection
09.09.23 14:32:10	ClientUI	Info	Connect status: Connection established
09.09.23 14:42:09	ClientUI	Info	Failed to autosubscribe, invalid state	```
I confirm, I also need to refresh my channel subscription.
Hello. I have problem. Im logging teamspeak. all working fine and every few mins my TS reset like i have no privilages at all. Why is that ?
i lost all my cloud favorites.
and i want to restore them.
is there any progress on fixing problems with disappearing bookmarks?
