If by ”username” you mean your myTS and this forum’s username, it’s impossible to change it at this moment. No one outside TeamSpeak knows when it’ll be available.
This topic was mentioned multiple times by now and there are dozen or so posts about this. Was searching too much?
Deleting myTS account is possible by sending an email to TeamSpeak, but right now I’m not 100% sure what address it was.
This is the error I get whenever I try to change my user name, general basis (not on a server), by going into parameters, and when I try to enter a username (tried with different ones), I always get that critical error.
So my username for my TeamSpeak is currently 1A-3, I want to change it to my name or ItzNikB, but when I go to the MyTeamspeak section of the Teamspeak and press change username, it keeps saying unable or failed to change username, not just one name I’ve tried lot’s of names and none of them work. Can I please get some help?
We’re not defending TeamSpeak, but that’s the way things are right now. If TeamSpeak says that they currently have to disable the “Change the Nickname” feature for technical reasons, then it has to be accepted. It will be unlocked in the future after all, so what is your problem?
Yes we have to accept it I agree. However for how long? As previously said it has been what two years maybe??
In terms of Technical if we were told why then maybe it would stop generating such long posts like this. I wish to change forum name and TS name none of which are possible. So that is my problem answering your ‘what is your problem’
When I change the nickname and enter the password, it gives an error and the name does not change, is it possible to change the name at all or is this option not available yet?
