I recently swapped CPU + Motherboard and now I cant join any TeamSpeak server, same with Discord. It says “Verbindung zum Server Fehlgeschlagen”.
Have a great evening
Looks like your PC is blocking the connection?
Well, I can go to any website without problems, I write right now on my Computer.
Have you already looked at this topic? You can't connect to a server?
Nothing worked :/.
Well Acually Discord works fine on my phone. So it has something to do with my Pc?
Have you a Software installed like Anti Virus Software that could block the UDP Traffic?
Ensure that your firewall allows TS to connect. Also try running the application w/ administrative permissions.
