Bad update . after updating ,my teamspeak client just wont open at all. had to reinstall ![]()
And then updating worked?
How did the Client behave?
You got a Log or crashdump? Or anything else?
I was just pressing the restart button for the update… and then nothing happend. No the update isnt working
Please try to answer all the questions from my Last Post.
Additional questions to this.
Which Operation system is this?
What Happens without Restart Button? Just Close the client and then start it manually.
OS: Windows 10 Pro
Restarting it manually doesn’t change anything, it just wont open
Have you checked the task manager, if there are any running tasks still there?
nothing there
Is there a way to stop ts from updating automatically, so that i can at least use it on the version before the update which is working?
Auto update can’t be disabled.
My first questions about a log or anything else remains unanswered.
Also make sure that your drivers are up to date and hardware still got some updates the last 2 years.
Same counts for Windows updates.
You may try to start the client with this parameter --no-sandbox
Explained in more details.
Adding this changes nothing for me. As for the logs, I don’t know how to get them :-/
Edited my post. Must be
--sandboxas shown on the picture. -
Open this folder. Clear all files in there. Then start the client.
%LOCALAPPDATA%\TeamSpeak\Logs\Default
Remains
Everything is up do date. Which file should i send, i guess its the cef.txt ,is it?
All in a zip.
but i got i got 850 files in there
i wrote this!
Then start client and send what is generated.
Oh sorry, but i cant send zip files, they aren’t authorized to send
Upload it here https://easyupload.io/ or anywhere else you want.
PS i will move the conversation to a new thread where it is only about your issue!
@Vantreex
Ok shows nothing i can work with.
- What hardware do you use?
- Press
Win + Rkey - Type
dxdiag - In the dialog you will find Save All information
- Upload the file
is there a crashdump? Please clean folder first and then start client and see if a new one is generated.
%LOCALAPPDATA%\TeamSpeak\User Data\Crashpad\reports -
Anything in windows error report about that crash?
- Press
Winkey - Type Event Viewer
In the event viewer you find Windows logs > Application
In Level should be a red x
The Event manager didn’t show any errors. Upload Files Easily | Fast File Upload and Sharing Up To 10GB
