The Error is normaly…
When i start my TeamSpeak5 Client, every time this get appended.
0227/065405.401:ERROR:gpu_init.cc(523)] Passthrough is not supported, GL is disabled, ANGLE is
Can you run TeamSpeak as Administrator?
When this not work, please have a look at %localappdata%\Programs\TeamSpeak
and execute patcher.exe
as Administrator
PS: You need to close TeamSpeak before running the Patcher
I can run TeamSpeak as Administrator. Doesn’t solve the update issue or the cannot open issue. I don’t have the patcher.exe where you pointed to. I found the patcher.exe in the installation directory, but executing it as admin did nothing…
Anyone with that issue may try to use beta73.
Chromium was updated and maybe the issue was fixed.
i can confirm, the issue is fixed now many thanks
