Don’t know if this is the right place but my TS keeps saying my headphones and mic aren’t connected while I don’t have any connected to my PC. I haven’t event uses headphones or a mic in the past three months on this PC!
So TeamSpeak says (correctly) that there is no audio device?
Where’s the problem?
It says “Speakers/Headphones Disabled” Ive tried everything I know and ive event deleted TS and redownloaded it
edit
If you don’t have any device selected then this is right.
You may setup that at least the internal sound card is used.
Else you must live this message.
Optional you can setup your bookmarks to use no capture and playback profile. So no check is made for any device. But that’s not the intention of the client!
