Hi. I applied for a sponsorship license earlier today for our community. It said that I was supposed to receive a confirmation email for my application, but that never arrived. Will my application be processed or was there a problem?
Hey,
Gave this a quick test and it seems to be working ok. There’s an overall guide for applying for sponsorship here which gives you more information about applying in general, but also some guidance if you don’t receive the verification email.
Other suggestions would be:
- Add the contact [email protected].
- Try to verify your mail server configuration and logs.
- Check your spam folder.
- Try whitelisting teamspeak.com
Failing that, email support here and someone can check the application for you.
