Failure to connect to servers
Whenver i try to connect to servers, it takes forever, then just says failed to connect or disconnected, i might see a channel or two for 30 seconds, then nothing. ive checked firewalls, antiviruses, and cleared dns cache, i have ethernet connected gigabyte internet. I cannot seem to figure out what is going on.
Hello @tylert99 and welcome to the TeamSpeak Forum.
Please post your latest TeamSpeak 3 Client. The Client Log
can be found under the following Path: %AppData%\Roaming\TS3Client\logs
And please take a closer look at this thread, there are good solutions that might help you:
