Hotkey on Gamepad/Joystick/Steering Wheel can not be set
I wanted to ask for help with Teamspeak. I have been on and had everything working perfectly, but I recently got a new computer and when I reinstalled Teamspeak, i am having issues with push to talk. I use push to talk because i use speakers for my engine sound and don’t want to annoy everyone. Before, I had no problem assigning my ptt button but now it wants me to do a button combination. In other words, I assign my ptt button and then have to also hit another button, either mouse or keyboard. I have Googled and spoke to several people for a fix and can’t find one. Has anyone, by any chance, heard of this happening?
When another button is required, then the first device does not send any key up event.
I assume (because you gave zero details about any operation system or device or client):
You are using a game pad or joystick or steering wheel.
Check your drivers, if it worked before this might fix it.
I am on Windows 11 and using a dedicated ptt button. It is for iRacing. It recognizes the button and assigns it but wants a second button pushed as well.
As i wrote whatever your device or software or etc. sends is a key down event.
But the dialog waits for any key up event to close.
When mentioned key does not send any key up event, then the dialog won’t close.
Do you have any idea why this would be happen on a different computer? It worked perfectly before. Same button and also Windows 11 before.
Maybe missing drivers or later driver versions for that device causing a different behavior.
But no I don’t know why.
Yes I have an idea. I’m confident it has something to do with USB device name reported to TS. There was EXACTLY same issue few years back with virtual functions on USB controllers (see above) and now it seems to be related to more complex USB architecture and most likely to USB4.
As written above, you may try to use USB 2.0 ports and it MAY get better because of more old school USB device name/path.
Unfortunately, there is deafening silence from devs for looong time :frowning:
Thank you for that information. I will pass it along to my tech buddy. I am hoping to get this figured out.
In the past I have used the add on for joysticks/game pad to use my racing wheel for push to talk, but now it is insisting on a combo of wheel and keyboard which is near impossible when racing in VR. Any ideas why it wont let me use only one button like in previous versions? Or know of a work around. both the new TS and old ver 3 have the same issue now!
Why don’t you do it with the PTT button? New computer set up, all controllers tested, always want second button, mouse 1 or whatever. So many people have this problem and can’t understand why nothing happens.
I answered that already.
As long your device or driver won’t send the key up event, then the dialog won’t accept it as a hotkey.
The dialog is build that way and for most users this is what is to expect or else they must setup each key twice with a key down and up event.
We won’t change that and make it complicated for everyone just because for whatever reasons a device won’t forward it’s key up event.
At least in my case problem is that after first key down event entire plugin freezes. That’s why there is no key up event, or any other event at all until plugin is disabled/enabled.
on win 10 my solution was to install vjoy. don’t use it, just install it.
it seems vjoy updates the joystick driver.
my winwing throttle works fine now in teamspeak.
Joy2Key didn’t work for me, but AntiMicro did the trick. It’s disappointing that after all these years, TeamSpeak still refuses to address this issue. There are so many WinWing users who, unfortunately, are forced to rely on third-party solutions instead of proper native support. I also tested other programs, like Discord and Ventrilo, and both worked without requiring any additional tools.
Remarkably useless responses from TS staff on this. Just repeating the same answers without reading what’s actually happening.
I have a Logitech X56, and for many years I have had one of the hat buttons bound to a TS3 PTT hotkey without any problems. However, after switching to an AMD CPU, this no longer works. The TS3 hotkey dialogue refuses to acknowledge the button being released - and if you bail out once this has happened, and then go in and try again, it now refuses to acknowledge that button being pressed at all. You can go through every button on the device one by one, until the dialogue is no longer registering any of them.
No other software on my entire PC has this problem. All buttons are correctly detected - including when they’re released - by every other game that supports the device at all, and by the Logitech config software. TS3 is the only place where this issue happens, and it’s only since I switched to an AMD CPU, much like many of the other people reporting in this thread.
I have the latest available version of the Gamepad and Joystick plugin installed. TS3 is up to date. The X56 drivers are up to date (as up to date as they’ll ever be, anyway).
This makes it impossible to use TS3 with my HOTAS because I’d have to take my hand off the stick to find my mouse or keyboard and press the PTT.
This is because after receiving first button down event entire plugin crashes. If you restart the plugin it will again accept first button down event, so it is easily verified.
I already pointed out it already happened once and it was related to USB enumeration issues. I was in touch with dev who fixed that back in the day.
There was not much reaction to that from TS staff unfortunately.
Actually I do not think the plugin crashes.
What happens is TS3 never understands the button release.
So whenever you try that again TS3 still thinks in its memory the button is pressed.
Because if you try another button it will recognise it but then again will get stuck on release phase.
The interesting part is I have two flight sticks for space sim. Right one works perfectly fine out of the box. And only the left one (where I actually need my PTT buttons) is having the issue.
Im trying everything but nothing seems to help right now.
