How can I call someone
How can I call someone?
Before you continue, please note that TeamSpeak does not currently offer calling services. TeamSpeak uses a client-server model, whereby users connect to a specific server via an address and, if applicable, a password. The server hosts channels that users can join to talk to each other. All voice data is transmitted directly through the server.
You can connect to multiple servers at once, but you can only talk on one server at a time.
How do you connect to a public server?
The easiest way is to join one of the featured servers displayed on the dashboard. You can also visit Community Discovery from there, where you can find even more servers.
How do I connect to a private/friends server?
If you choose to use a private server that you or a friend host, you can use the search bar in the top left corner to search for the IP/domain, or you can use the search bar on
Where on the server can I talk?
In most cases, the default channel is moderated and does not allow voice communication. You can then just double-click on other channels and join them. There, you can meet up with your friends.
On most servers, you also have the option to create a custom channel for you and your friends. Just tell them where you are and they can join too!
How do I leave the server?
By default, clicking the X in the top right corner will automatically leave the server. If configured otherwise, press the X next to the server in the left sidebar.
How i can CALL/TALK with someone on TS5?
After starting the TS5 application, enter in the search field the desired IP server, for example Official TeamSpeak Beta Server - IP: beta.voice.teamspeak.com
After that you click on Quick Connect
After connecting to the server, you have to join an existing channel or create your own private channel with or without a password.
After clicking on “Create”, you can see that you are in the created channel
You can also connect with a simple one-click on one of the public servers, to see all public servers follow the following steps:
@Psebcool @Junk_Lover @xKenpachi21 Can you all please understand that TeamSpeak is not Discord? Yes, they’re both voice communication platforms, but they work differently and have completely different monetization strategies. One runs by making your data the product, while the other relies on a paid service. There are still big community servers like mine where you can enjoy a completely free experience - at the expense of the server owner. So stop running around expecting everything to be free, thats not how our capitalist world works. If something is free, you are the product.
Can you Voice Chat in Group Chats?
