Hey, can you tell me how to do the spacers like you did?
Which ones?
Like “clan-section” and the channels with the background images
Let me just throw you the names of the channels and then you yourself)
[rspacer]┍╼ ᴄʟᴀɴ sᴇᴄᴛɪᴏɴ ╼
[*spacer0]—
[cspacer]Name your channel
And channel pictures (Banners) are available only for TS5
Well, the size of the banners: 1600Ń…60
Ok thank you very much!
So just set the banner in the description with the img tags?
I got TS5 and cant see a banner field or am I just blind?
Thanks found it!
As for the size, I’m 100% not sure, but I use this one, it seems that only the main channel looks a little smaller)))
Wow, that’s cool
Can ts3 users see that too?
TS3 Client can only see the Spacer. Not the background or channel banner.
