To use the custom theme engine implemented in TeamSpeak you need to follow the instructions of the Extentions.md which you can find here or in the docs folder C:\Program Files\TeamSpeak\docs
Thanks a lot. I used your json and stuff from colorful Teamspeak as a template. I will change everything and credit you even though that file is never leaving my computer
I’m literally using the “main.8e5f713b16ed35ba7cc7.css” css file. I’m just modifying it o.O
So don’t worry about your 50kb file, I’m using the original 400kb file
Add a custom flag to your desktop icon --remote-debugging-port=9988 and open it in your browser by typing localhost:9988 this way you can work on your css much easier.
