Having a bit of an issue with adding lower roles and them not showing.
This is a higher role, with group add power of 70!
This is a role with a needed add power of 70!
When I use the Higher server group with an add power of 70 to add the Lower role with the needed power of 70 this happens.
If you need more information please ask so, I will supply it immediately!
EDIT: I have looked over the forum for a little now and can’t find any answers so the help will be appreciated.
You are not using any Skip permission or the Skip flag on the Add power so any channel group or channel permission will mess with it.
Open the permissions overview on yourself and you will see why your add power is below 70.
