Privilege key for server wont work
When I enter my API-KEY it will say its invalid or has been used before even though i have not used it. Please help!
The API key does not say it is has been used before. You are talking about the Privilege key and you need to create a new one in case yours does not work for you.
Ps there is no need to create more than one topic for same issue!
