Hello my dears,
I would need the help of a few TeamSpeak affines.
I have a little problem which has a big impact on my server:
I have removed the right b_serverquery_login from all groups. Yes I know, this is very stupid.
And now I cannot login as a query anymore. I should have known that.
How can I add the right again without resetting the server?
Thank you very much in advance.
Best regards
retpircs
Assuming you removed this permission even from the admin server query group (not a normal server group but a query group) you will have to go into the database.
Oops, I expressed myself wrong. The admin server query group should still have this right.
Well then you can just login with the serveradmin user and set the permissions that way.
But can’t you just change the permission through TS3 itself?
No active local server group has the right.
Only the admin server query should have this right.
I cannot connect to the server as a query.
With which user?
guest
serveradmin
or some other?
Neither as admin, nor with any other user.
Can you check this table of the database file?
Ok, then it should work I guess…
What is the exact error you get from the query?
The connection was established, but no data was received.
~YaTQA
Could you try to connect directly via telnet? (putty or linux internal)
Oh, I see, it’s getting late…
This happened after trying to connect or after entering the credentials?
Directly after connecting.
We landed on the following:
- Firewall is not the problem.
- Query is running per configuration.
- Connection is possible from server but not a remote network.
- The query is listening to IP
* on IPv4 and IPv6
- Neither telnet, nor ssh, nor web query work.
- The connection is established but instantly closed again by TeamSpeak.
@TS.ChrisR please help
