Spacer alignment
Left alignment
Different spaces types are not aligned at the left side.
Intoduction
Using
[spacer]---
[spacer]___
You can create really nice lines straight across (like a [*spacer])
Example
[spacer]___
[*spacer]_
[spacer]---
[*spacer]-
I see two “problems” with this.
  • the markdown syntax with three characters (___) creates a centered line every time
    while the [*spacer] syntax really just repeats the character. (I can see how this is intended)
  • They do not line up at the left side.
The first “problem” can simply be fixed by using markdown syntax with a [*spacer] thus naming the channel [*spacer]___ or [*spacer]---
However the second problem persists.
[Fixed] Spacer length
Using [*spacer] will not fill the entire length!
It stops at 128 chars. I see you need some kind of max recursion depth / loop max but 128 seems a little low.
[Fixed] Default → spacer channel
Creating a non-spacer channel and then renaming it to a spacer will only be shown after reconnect.
(Changing spacer type or name will take affect instantly)
As of 2021 the left alignment remains unchanged
Beta 62 fixed the left alignment (finally :partying_face:)
HOWEVER: The max length of [*spacer]s is again 128. This can be too little for wider monitors or higher resolutions.
If you don’t want to extend the char count (static or dynamic) here is a solution that’s in pure CSS - all dynamic:
JSFiddle - Code Playground
Thanks to the 50th person clicking the link and thus reminding me of this problem. The max width is indeed still a problem, so sorry for bumping.
TID: 2070
This issue should be fixed with the next update. 6.0.0-beta4
