Stream stops when specific client joins
Hi folks,
I´m experencing issues when a particular buddy joins a stream. The person is not connected via VPN, and everytime he connects to the stream it immediately stops for all watchers, when he leaves it starts running again like a charm. The problem started 3 days ago (06/12/2026) out of sudden, before everything was working fine on his side. No changes on serverconfig (I know peer2peer, but for the sake of completeness mentioned) or clientconfig were performed.
Any idea?
Thanks, Hefe
Can you provide further system information about the user causing the issue? OS/GPU/CPU
Also logs would be very beneficial, If necessary please censor the IP addresses for the screen share sessions.
