TeamSpeak 3 Client 3.5.0
We just released a new bigger TS3 client update.
A lot has changed and a lot has been fixed and added into this version.
  • You can now connect to the free servers (generated in TS5 client)
  • Automatic voice volume leveling (AGC) is no longer a recording setting. We moved that feature into Playback.
    Clients with older version may not hear you as loud as before. Please tell them to update their client.
  • This versions adds a new settings for capture when using VAD.
    When updating old capture profiles the client will select Volume Gate.
    Automatic is selected for users without old config or when a new profile was created.
  • Multi track recording has been improved and a crash got fixed here
  • The Plugin API ws raised to 24 but client still will be able to use plugins that are build on version 23
  • A whisper bug where whispering user moved into unsubscribed channel (it’s not in the change log sorry)
More changes below :smiley:
=== Client Release 3.5.0 - 19 Mar 2020
! Updated Plugin API version to 24.
+ Added new voice activity detection modes (Automatic, Volume Gate, Hybrid).
+ Added automatic voice volume leveling option in playback settings.
+ Added typing attenuation feature to try to reduce the sounds made by typing.
+ Added comfort noise feature to add synthetic background noise to fill the
  artificial silence while being connected to a TeamSpeak Server.
+ Added optional -connect commandline parameter to specify an address for
  auto-connecting on startup (example: -connect=voice.teamspeak.com). Some
  additional parameters can be used to provide more details (-pw, -nickname,
  -channel, -channelid, -channelpw, -newtab, -mytsid, -showqueryclients,
  -capture, -playback, -hotkeys).
+ Added support for upcoming TeamSpeak Server releases using a PostgreSQL
  database backend.
+ Added hotkeys to assign, revoke or toggle specific server groups based on
  current group memberships (e.g. mute clients in a specific raid group).
+ Added volume toolbox widget for quick access to microphone volume gate,
  overall and individual client volume levels.
+ Added convenience variables and options to infoframe templates.
+ Added active badge showcase to client infoframe templates.
+ Added design option to show/hide client badges in server tree.
+ Added server/channel group icons to client context menus.
* Moved server/channel group IDs to tooltips in permission settings.
* Improved client context menu to filter inaccessible groups and permission
  related tools.
* Improved echo cancellation and noise reduction systems.
* Improved error handing for multi-track recording.
* Infoframe templates now support "??" modifier for variables to prevent their
  value from being shown so they can be used conditionally to determine whether
  or not a specific line should be hidden (e.g. %%??CLIENT_FLAG_AWAY%%).
* Remote icon list is now sorted by upload date/time rather than icon ID.
* Qt color roles can now be customized in themes (e.g. for hyperlinks).
- Removed AGC from audio capture settings in favour of playback AGC.
- Fixed a bug where mutli-track recordings could cause a crash when clients
  join or leave your channel.
- Fixed a bug where multi-track recordings were not saved on server shutdown.
- Fixed a bug where custom displaynames for clients were shown in infoframe
  even when it was equal to the nickname of the client in view.
- Fixed a bug where default capture/playback profiles could not be switched.
- Fixed a bug where deactivated plugins were loaded when launching the client.
- Fixed crashes reported by crashdumps.
You can download the update in the client by clicking on Help → Check for updates.
The installer on our website and service page will be updated within next 24 hours.
why is TS3 still being updated when TS5 already exists?
Finally! :smiley:
Because alot of people still do use TS3 - once because we still like it, otherwise we need it. (e.g. for server administrators which do need the permission system)
The support for TS3 didn’t get dropped overall, and TS5 is still a beta. :slight_smile:
Not everyone owns the TS5 closed Beta yet and some can not connect to the free servers (generated in TS5). So at least that must be done in one or the other way.
Note:
Please do not start a discussion about the TS5 client in a TS3 release thread :smiley:
I assume that the files have not been updated yet on the site?
TeamSpeak Downloads | TeamSpeak - still shows the 3.3.2 clients
http://files.teamspeak-services.com/releases/client/3.5.0/ - empty path yet.
nice :smiley:
Uhh, how it looks like i have a very good eyesight :frowning:
that means, it’s now working as good as TS5?
then, no thank you. ts5 is completly broken and sends always. ts3 only if i speek. it’s not possible for some reasons to configure it like that in ts5 without headphone usage.
Was habt ihr mit der Lautstärke angestellt bitte? Ich habe einen Musikbot auf meinem TeamSpeak Server und dieser geht die ganze Zeit lauter und leiser das wurde bereits von “gesperrten”-Usern gemeldet aber wurde anscheinend verachtet. Bitte fixt es zur 3.5.1!
Das Problem ist ebenfalls im TS5Client.
Hast du die Musikbots auf 3.5.0 geupdated?
Es ist der TS3AudioBot.
der läuft schon lange auf der 3.5.0 :smiley:
Beim Sinusbot habe ich es noch nicht getestet.
Hm.. Mit dem Sinusbot habe ich keine Probleme.
Edit: Meine Sinusbots laufen noch auf 3.3.2
Hmm komisch
Hello, this update 3.5.0 is completely broken my players indicate me problems of mute and my music bot speaks complement loudly and even my friend who is yet in 3.5.0 speaks as loudly with the button activated: Automatic voice volume leveling must be removed this option is useless!
Hi everyone,
I were using teamspeak since teamspeak2 without any problem. Today, I decided to update my TS3 client to the last version like I always do. However, I had to uninstall that version becuase it was returning an error everytime that I tryied to open it. I tryied to uninstall and install again the last version, but I were getting the same. Then, I downloaded a older version to speak with my friends and I can use it without any problem again.
I am writing this just to know if there are more people like me.
Regards,
As for me the client works fine from it’s beta stage until now.
What error do you get? Maybe it’s something else that needs to be fixed.
same here.
Solved after overwrite with the older version 3.3.2.
