I works now! Tyyy love ya all <3
The new volume leveling is indeed a bit weird. Before it worked flawlessly, but now it fluctuates weirdly.
When my friend starts talking, he is very quiet and gets automatically boosted, which is fine. But after a while the boost gets reset and he is again very quiet and gets boosted, which takes a second and we can’t hear him in the meantime.
And yes, we are both on 3.5.0.
Please look into this.
This is happening every time I launch TeamSpeak. I clear the cache and then it works but when I close and reopen TS it crashes again. It is definitely a problem with the servericons.dat but my server’s icons and configuration has not changed (I’m the owner). Even if this was the case, other people are connecting fine with the same version and are not experiencing the crash. I disabled all of my plugins and this still occurs so I don’t think it is plugin related. I reset my theme back to the default and that did not resolve it either. If the icons are getting corrupted the application should still not be crashing on load like it is.
We are having a massive issue where people will randomly get turned up to a deafening amount, this is happening to multiple clients and multiple clients are also being turned off, having AVVL on or off makes no difference. If someone has any idea how to fix this please share so we can stop going deaf
After I updated to 3.5.0, ts just doesn’t launch. When I attempt to, it just suggests to me to send a bug report. Yes, I tried launching it in safe mode (-safeload), but it doesn’t work. Right now, I can’t be bothered to reinstall 3.3.2, so I’m just using ts5. Anyway to solve this problem?
Maybe delete cached data and saved channel data. Maybe the data got corrupted.
Have a look at this.
There has been a lot of discussion about this.
Sent: 16384/50242 bytes
Sent: 50242/50242 bytes
Error: 201
<?xml version="1.0" encoding="UTF-8"?>AccessDeniedInvalid according to Policy: Policy expired.679A29B0C96782E6tFJNPzxf8KEUNXauMUmmNbg1Gs+KyQJrN25adzACLBAyMjzrhiBolGtq4IdSmyzvBNMZFnTs9vQ=
Client 3.5.1 got released, but there is no Changelog here…
Yes and a release thread will happen.
You can find the changelog in client already.
Thanks
Client update 3.5.1 is available in the update channel.
Please visit https://community.teamspeak.com/t/teamspeak-3-client-3-5-1 for further details ![]()
