TeamSpeak 3 Client 3.5.0
Interesting, this worked.
sid=0 serverinfo showed me basically default settings, sid=1 showed me the settings for my actual instance. Thank you very much!
I wasn’t aware that there’s more than 1 sid for an unlicensed server (basic install with 32 slots)
OK - have the issue with crash at startup, empty cache is working, but have to do this everytime before start the client. Found out that’s enough to delete servericons.dat file …
Regards
Volker
thanks for that tipp
there is a easier solution to solve permanently after first start:
clear cache on exit
Can you please share the file? Would help us to at least reproduce it that way.
We found out that the server icons stored in bookmarks are the reason. We are working a fix.
I can share my File since I have the same Problem and the Workaround also works for me in that Way.
And just in Case here’s also my Crash Dump
Hello there,
I also had the problem with starting TS3 after updating into 3.5.0 verison.
<?xml version="1.0" encoding="UTF-8"?>
AccessDeniedInvalid according to Policy: Policy expired.79A412F61C6B91CF
I had to delete the folder cache and now it is working well.
Thank you for this forum and good ideas.
Czecher
Mic or Playback Volume is out of control. Even when AGC is turned off in the playback settings, my own mic test is definitely changing volume a lot. It’s comparable to the old recording setting that normalizes your mic (which I have always turned off, like all the other options in the recording tab).
Although it’s off, the mic volume is always changing dynamically which is very annoying.
For now, I will roll back to the older version.
https://drive.google.com/open?id=1njWD4QqV_UPzWcZAUrILwpYe-dWlgos1
here it is …
Hello, I cant use my myteamspeak anymore and need help.
Description:When i log in into my myteamspeak account my style get changed and if i click on the settings by client going to crash.Since the Stable version of 3.5 and with the plugins ( Lua, Watchdogs , DockWidgets , rp Soundboard and autoreply) my teamspeak get changed as an example icon get changed as an microphone i see just numbers or e.t.c . Need Help!
Yes ofc i did but everytime if delete these plugins from my folder it load again if i log in again,and if i go to the settings it gonna crash.
Use start parameter -safemode
In case this does not work follow this one
Dankeschön! / Thank you!
Since the 3.5.0 Update we perceive some annoying noise in the background even of our musicbots(digital signal should be clear). We disabled Comfort noise, enabled background noise reduction, installed the newest server version and set the channel codec to Music 10 etc.
The noise isn’t going away and I’m clueless what to do. This bug is not only annoying but hurting our ears.
If I disable this option it’s still active for me for some reason. Needed to downgrade becuz I don’t wanna earr*pe my friends
same. can’t disable this option and my voice gets louder and louder…
This is the exact definition of the problem that I have to and you can’t disable this…
PLEASE FIX!!!
I have the same issue, Get a “Client crashed” after i start the teamspeak 3… I try “-safeload” doesnt work… And i dont get any Cache folder in my appdata… So i cant clear that too. I dont know what to do? Any helps?
in the Client crashed i get this :frowning:
Sent: 16384/49392 bytes
Sent: 49392/49392 bytes
Error: 201
AccessDeniedInvalid according to Policy: Policy expired.0E54CC83E883D5E30iK++mjBZ+C9rSmao5Qg/28wE8/xyHSineFO7kRd8W1nHqBMQCKKp76tMbVVRuBqmRfKab3DZJw=
I never said to disable anything. I said
which should be done as quick as possible. Updating client is very important.
Please scroll up some posts and read my big post with the image shown.
