Hmm strange… maybe there is trouble with my devices?
Using Airpods Max and a USB Blue Yeti as microphone.
Here all the 3.6.0 logs on my attempts to load the app:
On log at least shows devices as last action. But may mean nothing.
Have you tried disconnecting one or both devices?
I downloaded it again, opened the dmg and moved the app in programs folder. Set the devices to internal MacBook Speakers and Mic. Still crashes:
2023-06-14 22:43:38.556133|INFO | | |TeamSpeak Client 3.6.0 (2023-06-14 13:36:04)
2023-06-14 22:43:38.556395|INFO | | |SystemInformation: Darwin 22.5.0 Darwin Kernel Version 22.5.0: Mon Apr 24 20:52:24 PDT 2023; root:xnu-8796.121.2~5/RELEASE_ARM64_T6000 x86_64 Binary: 64bit
2023-06-14 22:43:38.873889|DEBUG |SoundDevManager| |Error resolving soundbackends folder (/Applications/TeamSpeak 3 Client.app/Contents/SharedSupport/soundbackends): No such file or directory
2023-06-14 22:43:38.948620|INFO |ClientUI | |OpenGL Info: LibGL, Vendor: Apple, Renderer: Apple M1 Pro, Version: 4.1 Metal - 83.1
2023-06-14 22:43:39.067193|INFO |Addons | |Checking for addon updates…
2023-06-14 22:43:39.256284|INFO |Plugins | |Loading plugin: libclientquery_plugin_mac.dylib
2023-06-14 22:43:39.258841|INFO |Addon | |Not available for this platform.
2023-06-14 22:43:39.261555|INFO |Plugins | |Api version is not compatible for plugin: /Users/nikolaischwarzl/Library/Application Support/TeamSpeak 3/plugins/libclientquery_plugin_mac.dylib
2023-06-14 22:43:39.566330|INFO | | |*** Time [MAINWINDOW]: 403
2023-06-14 22:43:39.566457|INFO | | |*** Time [INIT]: 404
2023-06-14 22:43:39.615537|INFO |ClientUI | |Qt version: 5.15.8
2023-06-14 22:43:39.615775|INFO |ClientUI | |Using configuration location: /Users/nikolaischwarzl/Library/Application Support/TeamSpeak 3/settings.db
2023-06-14 22:43:39.835644|INFO | | |disconnected from push system.
2023-06-14 22:43:39.981797|INFO | | |connected to push system.
2023-06-14 22:43:40.067594|INFO |Bookmarks | |Collecting autoconnect bookmarks
2023-06-14 22:43:40.068573|INFO |ClientUI | |Last update check was: Mi. Juni 14 19:53:24 2023
2023-06-14 22:43:40.069494|INFO |Update | |Checking for updates…
2023-06-14 22:43:40.204103|INFO |Update | |License update available; version 5 to 5 (min version 5 to 4)
2023-06-14 22:43:40.204245|INFO |Update | |Latest client release on channel ‘stable’: 3.6.0 [Build: 1686749764]
2023-06-14 22:43:40.204293|INFO |Update | |Client is up-to-date
2023-06-14 22:43:40.204884|INFO | | |Statistics report: Not yet, next report on Fr. Juli 14 19:55:02 2023
2023-06-14 22:43:40.221392|INFO | | |successfully downloaded revocation list for myteamspeak id
2023-06-14 22:43:40.567892|INFO |Newsticker | |Newsticker next check: Do. Juni 15 17:53:25 2023 GMT
2023-06-14 22:44:05.316998|INFO | | |TeamSpeak Client 3.6.0 (2023-06-14 13:36:04)
2023-06-14 22:44:05.317231|INFO | | |SystemInformation: Darwin 22.5.0 Darwin Kernel Version 22.5.0: Mon Apr 24 20:52:24 PDT 2023; root:xnu-8796.121.2~5/RELEASE_ARM64_T6000 x86_64 Binary: 64bit
2023-06-14 22:44:16.323815|INFO | | |TeamSpeak Client 3.6.0 (2023-06-14 13:36:04)
2023-06-14 22:44:16.324071|INFO | | |SystemInformation: Darwin 22.5.0 Darwin Kernel Version 22.5.0: Mon Apr 24 20:52:24 PDT 2023; root:xnu-8796.121.2~5/RELEASE_ARM64_T6000 x86_64 Binary: 64bit
2023-06-14 22:44:16.644949|DEBUG |SoundDevManager| |Error resolving soundbackends folder (/Applications/TeamSpeak 3 Client.app/Contents/SharedSupport/soundbackends): No such file or directory
2023-06-14 22:44:16.720592|INFO |ClientUI | |OpenGL Info: LibGL, Vendor: Apple, Renderer: Apple M1 Pro, Version: 4.1 Metal - 83.1
2023-06-14 22:44:16.804839|INFO |Addons | |Checking for addon updates…
2023-06-14 22:44:16.843795|INFO |Plugins | |Loading plugin: libclientquery_plugin_mac.dylib
2023-06-14 22:44:16.846591|INFO |Plugins | |Api version is not compatible for plugin: /Users/nikolaischwarzl/Library/Application Support/TeamSpeak 3/plugins/libclientquery_plugin_mac.dylib
2023-06-14 22:44:16.963000|INFO | | |*** Time [MAINWINDOW]: 372
2023-06-14 22:44:16.963121|INFO | | |*** Time [INIT]: 373
2023-06-14 22:44:16.978305|INFO |Addon | |Not available for this platform.
2023-06-14 22:44:17.006739|INFO |ClientUI | |Qt version: 5.15.8
2023-06-14 22:44:17.006960|INFO |ClientUI | |Using configuration location: /Users/nikolaischwarzl/Library/Application Support/TeamSpeak 3/settings.db
2023-06-14 22:44:17.464435|INFO |Bookmarks | |Collecting autoconnect bookmarks
2023-06-14 22:44:17.466326|INFO |ClientUI | |Last update check was: Do. Juni 15 00:43:40 2023
2023-06-14 22:44:17.466825|INFO | | |Statistics report: Not yet, next report on Fr. Juli 14 19:55:02 2023
2023-06-14 22:44:17.658475|INFO |SoundDevManager| |Core Audio - Device added:
2023-06-14 22:44:17.658631|INFO |SoundDevManager| |Core Audio - Device removedMSLoopbackDriverDevice_UID
2023-06-14 22:44:17.966083|INFO |Newsticker | |Newsticker next check: Do. Juni 15 17:53:25 2023 GMT
2023-06-14 22:44:17.988186|INFO | | |successfully downloaded revocation list for myteamspeak id
2023-06-14 22:44:18.085349|INFO | | |disconnected from push system.
2023-06-14 22:44:18.668439|INFO |SoundDevManager| |Core Audio - Device added: MSLoopbackDriverDevice_UID
2023-06-14 22:44:18.668799|INFO |SoundDevManager| |Core Audio - Device removed
@iL.Whesley i have to talk to our dev. I have no clue.
PS: The debug error itself is fine. Only happens with installer because the folder has no use any longer AFAIK.
@Dr.Spanky please read my full post above. We need more details (as i did list in my post).
The picture only shows the error reporter window.
Allright, hope you guys will figure out the problem. Here is a screen capture of the behaviour, maybe it helps:
Feel free to contact if I can help. Will revert to 3.5.7 Beta in the meantime. Good luck. ![]()
So since the new plugin and TS update it has broken many more plugins from working. I need to know how to fix this, it has also broken the uninstaller.
2023-06-15 00:21:04.212156|INFO | | |TeamSpeak Client 3.6.0 (2023-06-14 13:36:04)
2023-06-15 00:21:04.212156|INFO | | |SystemInformation: Windows 10 (19045) x64 (AMD or Intel) Binary: 32bit
2023-06-15 00:21:04.232964|DEVELOP |Windows Audio Session| |Hardware agc not available - Microphone (Blue Snowball)
2023-06-15 00:21:04.235965|DEVELOP |Windows Audio Session| |Hardware agc not available - Microphone (Logi C270 HD WebCam)
2023-06-15 00:21:04.236460|DEBUG |SoundDevManager| |Loading dynamic soundbackend from C:/Program Files (x86)/TeamSpeak 3 Client/soundbackends/directsound_win32.dll
2023-06-15 00:21:04.301909|DEBUG |Direct Sound | |setting timer resolution to 1ms -
2023-06-15 00:21:04.338716|DEBUG |SoundDevManager| |Soundbackend loaded.
2023-06-15 00:21:04.339212|INFO | | |*** Time [SPAWN_EVENTCONVERTER]: 127
2023-06-15 00:21:04.376412|INFO |ClientUI | |OpenGL Info: LibGLES, Vendor: Google Inc., Renderer: ANGLE (NVIDIA GeForce RTX 2080 Direct3D11 vs_5_0 ps_5_0), Version: OpenGL ES 2.0 (ANGLE 2.1.0.57ea533f79a7)
2023-06-15 00:21:04.484072|INFO | | |*** Time [ICONMANGER]: 102
2023-06-15 00:21:04.489005|INFO |Addons | |Checking for addon updates…
2023-06-15 00:21:04.505396|INFO |Plugins | |Loading plugin: clientquery_plugin_win32.dll
2023-06-15 00:21:04.506860|INFO |Plugins | |Api version is not compatible for plugin: C:\Users\rjfin\AppData\Roaming\TS3Client\plugins\clientquery_plugin_win32.dll
2023-06-15 00:21:04.507380|INFO |Plugins | |Loading plugin: gamepad_joystick_win32.dll
2023-06-15 00:21:04.509340|INFO |Plugins | |Api version is not compatible for plugin: C:\Users\rjfin\AppData\Roaming\TS3Client\plugins\gamepad_joystick_win32.dll
2023-06-15 00:21:04.509340|INFO |Plugins | |Loading plugin: teamspeak_control_plugin_win32.dll
2023-06-15 00:21:04.510828|INFO |Plugins | |Api version is not compatible for plugin: C:\Users\rjfin\AppData\Roaming\TS3Client\plugins\teamspeak_control_plugin_win32.dll
2023-06-15 00:21:04.602740|DEVELOP |Windows Audio Session| |DeviceDeleteList::wait_for_deletes - enter - DeviceDeleteList
2023-06-15 00:21:04.603236|DEVELOP |Windows Audio Session| |DeviceDeleteList::wait_for_deletes - leave - DeviceDeleteList
2023-06-15 00:21:04.745156|INFO | | |*** Time [BUILD_GUI]: 139
2023-06-15 00:21:04.764004|INFO | | |*** Time [SERVERVIEW]: 163
2023-06-15 00:21:04.772932|INFO | | |*** Time [SERVERVIEWMANAGER]: 184
2023-06-15 00:21:04.792850|INFO |Addon | |Not available for this platform.
2023-06-15 00:21:04.873374|INFO | | |*** Time [MAINWINDOW]: 665
2023-06-15 00:21:04.873374|INFO | | |*** Time [INIT]: 666
2023-06-15 00:21:04.882826|INFO |ClientUI | |Qt version: 5.15.2
2023-06-15 00:21:04.882826|INFO |ClientUI | |Using configuration location: C:\Users\rjfin\AppData\Roaming\TS3Client\settings.db
2023-06-15 00:21:05.283478|INFO |Addon | |Not available for this platform.
2023-06-15 00:21:05.374254|INFO |ClientUI | |Last update check was: Wed Jun 14 15:35:30 2023
2023-06-15 00:21:05.374750|INFO | | |Statistics report: Not yet, next report on Fri Jul 7 15:25:09 2023
2023-06-15 00:21:05.374750|INFO |Bookmarks | |Collecting autoconnect bookmarks
2023-06-15 00:21:05.704916|INFO | | |successfully downloaded revocation list for myteamspeak id
2023-06-15 00:21:05.873700|INFO |Newsticker | |Newsticker next check: Thu Jun 15 19:53:04 2023 GMT
2023-06-15 00:21:06.069375|INFO | | |disconnected from push system.
2023-06-15 00:21:06.260796|INFO | | |successfully downloaded revocation list for accounting
2023-06-15 00:21:06.344359|INFO |Addon | |Not available for this platform.
2023-06-15 00:21:07.824120|INFO |ClientUI |1 |Connect to server: werewolfgamingts
2023-06-15 00:21:07.829576|INFO |ClientUI |1 |Trying to resolve werewolfgamingts
2023-06-15 00:21:07.829576|INFO |TSDNS | |Trying to resolve server name: werewolfgamingts
2023-06-15 00:21:08.171347|INFO | | |connected to push system.
2023-06-15 00:21:08.482480|INFO |TSDNS | |Server name successfully resolved
2023-06-15 00:21:08.482480|INFO |TSDNS | |Lookup: 208.103.169.210:9987, parse result: IPv4 208.103.169.210 9987
2023-06-15 00:21:08.484960|INFO |TSDNS | |Server name resolved to IPs
2023-06-15 00:21:08.485457|INFO |ClientUI |1 |Lookup finished: ip=208.103.169.210 port=9987 query=werewolfgamingts error=0
2023-06-15 00:21:08.485457|INFO |ClientUI |1 |Resolve successful: 208.103.169.210:9987
2023-06-15 00:21:08.485457|INFO |ClientUI |1 |Initiating connection: 208.103.169.210:9987
2023-06-15 00:21:08.498042|DEVELOP |Windows Audio Session| |DeviceDeleteList::wait_for_deletes - enter - DeviceDeleteList
2023-06-15 00:21:08.498042|DEVELOP |Windows Audio Session| |DeviceDeleteList::wait_for_deletes - leave - DeviceDeleteList
2023-06-15 00:21:08.498042|DEBUG |Windows Audio Session| |WAS::openDevice-enter - {0.0.0.00000000}.{2dc56d16-166b-499e-9e53-776f36a475f3}
2023-06-15 00:21:08.502009|DEVELOP |Windows Audio Session| |Mix Format: SRate:48000 Bitrate: 32 Channels: 2 - VG245 (NVIDIA High Definition Audio)
2023-06-15 00:21:08.502009|DEVELOP |Windows Audio Session| |Initializing with mix format. - VG245 (NVIDIA High Definition Audio)
2023-06-15 00:21:08.517386|INFO |Windows Audio Session| |Initialized with 2 channels in 32bit, 48kHz. - VG245 (NVIDIA High Definition Audio)
2023-06-15 00:21:08.517386|DEVELOP |Windows Audio Session| |WAS Buffer size: 1056 - VG245 (NVIDIA High Definition Audio)
2023-06-15 00:21:08.517386|DEBUG |Windows Audio Session| |WAS::openDevice-leave - {0.0.0.00000000}.{2dc56d16-166b-499e-9e53-776f36a475f3}
2023-06-15 00:21:08.517386|DEBUG |Windows Audio Session| |WAS::startDevice-enter - {0.0.0.00000000}.{2dc56d16-166b-499e-9e53-776f36a475f3}
2023-06-15 00:21:08.517905|DEBUG |Windows Audio Session| |WAS::startDevice-leave - {0.0.0.00000000}.{2dc56d16-166b-499e-9e53-776f36a475f3}
2023-06-15 00:21:08.563403|DEVELOP |Windows Audio Session| |DeviceDeleteList::wait_for_deletes - enter - DeviceDeleteList
2023-06-15 00:21:08.563403|DEVELOP |Windows Audio Session| |DeviceDeleteList::wait_for_deletes - leave - DeviceDeleteList
2023-06-15 00:21:08.563403|DEBUG |Windows Audio Session| |WAS::openDevice-enter - {0.0.1.00000000}.{009695d4-6986-4a9c-9b5a-b3359b9e3f28}
2023-06-15 00:21:08.564396|DEVELOP |Windows Audio Session| |Mix Format: SRate:48000 Bitrate: 32 Channels: 1 - Microphone (Blue Snowball)
2023-06-15 00:21:08.564396|DEVELOP |Windows Audio Session| |Initializing with mix format. - Microphone (Blue Snowball)
2023-06-15 00:21:08.576796|INFO |Windows Audio Session| |Initialized with 1 channels in 32bit, 48kHz. - Microphone (Blue Snowball)
2023-06-15 00:21:08.576796|DEVELOP |Windows Audio Session| |WAS Buffer size: 1056 - Microphone (Blue Snowball)
2023-06-15 00:21:08.576796|DEBUG |Windows Audio Session| |WAS::openDevice-leave - {0.0.1.00000000}.{009695d4-6986-4a9c-9b5a-b3359b9e3f28}
2023-06-15 00:21:08.577320|DEBUG |Windows Audio Session| |WAS::startDevice-enter - {0.0.1.00000000}.{009695d4-6986-4a9c-9b5a-b3359b9e3f28}
2023-06-15 00:21:08.580764|DEBUG |Windows Audio Session| |WAS::startDevice-leave - {0.0.1.00000000}.{009695d4-6986-4a9c-9b5a-b3359b9e3f28}
2023-06-15 00:21:08.580764|DEBUG |Windows Audio Session| |WAS::associateAECDevice-enter - {0.0.1.00000000}.{009695d4-6986-4a9c-9b5a-b3359b9e3f28}
2023-06-15 00:21:08.581756|DEVELOP |Windows Audio Session| |Mix Format: SRate:48000 Bitrate: 32 Channels: 2 - VG245 (NVIDIA High Definition Audio)
2023-06-15 00:21:08.581756|DEVELOP |Windows Audio Session| |Initializing with mix format. - VG245 (NVIDIA High Definition Audio)
2023-06-15 00:21:08.584236|INFO |Windows Audio Session| |Initialized with 2 channels in 32bit, 48kHz. - VG245 (NVIDIA High Definition Audio)
2023-06-15 00:21:08.584236|DEVELOP |Windows Audio Session| |WAS Buffer size: 1056 - VG245 (NVIDIA High Definition Audio)
2023-06-15 00:21:08.584733|DEBUG |Windows Audio Session| |WAS::associateAECDevice-leave - {0.0.1.00000000}.{009695d4-6986-4a9c-9b5a-b3359b9e3f28}
2023-06-15 00:21:08.584733|DEVELOP |Windows Audio Session| |[Echo] IAudioClient::GetDevicePeriod - 10.000000ms - VG245 (NVIDIA High Definition Audio)
2023-06-15 00:21:08.623419|INFO |ClientUI |1 |Connect status: Connecting
2023-06-15 00:21:08.724603|INFO |PktHandler |1 |server sent ciphers:1
2023-06-15 00:21:08.837195|INFO |PktHandler |1 |Selected cipher:0
2023-06-15 00:21:08.837195|DEVELOP |PktHandler |1 |Puzzle solve time: 5
2023-06-15 00:21:09.351190|INFO |ClientUI |1 |Connect status: Connected
2023-06-15 00:21:09.455847|INFO |ClientUI |1 |Connect status: Establishing connection
2023-06-15 00:21:09.613224| |KeyBindings | |Default monitoring disabled
Plugin authors need to update them to API 26. But if you want your plugins to continue working, you can downgrade back to the previous TeamSpeak 3 client version
Please use the following link to download the previous TeamSpeak 3 client version :
thanks
People that have updated to 3.6.0 on my server seem to have louder audio through their microphone than normal for a split-second sometimes when they’re talking (it’ll kinda sound like popping audio), it’s something I noticed in the TS5 beta as well, and didn’t happen until 3.6.0 on TS3, please look into this as it’s quite annoying sounding.
@Dr.Spanky @Hope @N4then @Somara_Ilic
We found a crash in WebRTC when Echo Cancelation is enabled in a 32-bit client.
As a temporary solution you can do 2 things (please move to 64 bit and ignore the second option
Download and use the 64 bit Cleint.
https://files.teamspeak-services.com/releases/client/3.6.0/TeamSpeak3-Client-win64-3.6.0.exe
Open the client and in the Capture settings (Tools > Options > Capture) turn the Echo Cancellation off
A post was merged into an existing topic: Ts3 3.6.0 addons incompatible
I am pretty sure I just set it ‘again’ (after disabling it before) in 3.5.6 …
(current / new workaround I use is using the Beta 5 Client, because it ignores the Master password)
You did set the master password in this release from yesterday and this on stopped working immediately?
This is fine here.
TS5 client does use another client database. This is why it does not care about that password at all.
Do you have Microsoft Teams or other apps with virtual audio cards installed (Mac OS > System Settings > Sound)?
You have a device from Microsoft listed in your logs. I do not see a device on my Macwith MS Teams installed or running but can choose it in the client.
I have MS Teams installed, but no Microsoft Devices in System>Settings>Sound. There are 2 Airplay Devices as Output and a Virtual Mic from the Hue Sync App however.
Philips Hue virtual audio device is know that it can crash the Mac client.
We had the topic here
Currently we do not have a solution for this crash.
