The stable version for TS3 client 3.6.0 was released.
The most important change in that client is the ability to connect to our upcoming TS5 server
The compatibility to TS5 servers is the main reason why we made this release public.
We have a TS5 server prepared for this case beta.voice.teamspeak.com
=== Client Release 3.6.0 - 14 Jun 2023
! Plugin API increased to 26 as workaround for Qt update incompatibility
+ Added option to automatically select channel chat tabs after connecting to a
TeamSpeak Server.
+ Added support for OS dark mode stylesheet extensions (<style>_darkmode.qss).
This also supports platform specific extensions (<style>_mac_darkmode.qss).
* Improved overall compatibility with TeamSpeak Server version 5 and newer.
* Tweaked icons based on user feedback.
* myTeamSpeak sync now utilizes push service instead of polling periodically.
* Certain Microsoft specific URL schemes will no longer considered to be valid
when using [URL] bbCode tags.
* Additional Linux dependencies:
sudo apt install libxcb-xinerama0 libatomic1 pulseaudio fontconfig
libxcb-icccm4 libxcb-image0 libxcb-keysyms1 libxcb-render-util0
libxcb-xkb1 libxkbcommon-x11-0
- Disabled server list browser
- Fixed a crash on macOS versions 11.3 and newer.
- Fixed an issue with duplicate names for cached badge icons.
- Fixed an issue where channel groups were not shown in client context menus
when an inherited group has been set.
Other notes for this release
We dropped the support for Linux 32-bit. The updater itself will offer you the update but will fail. Please consider to move to a 64 Bit operation system.
MacOS clients will show OS X. We leave that in there for compatibility of the TS3 SDK
MacOS clients are now notarized again.
The server weblist was removed from client.
The topic is not dead but we get to many tickets about a broken weblist. As long we did not not start the weblist again, we won't add this feature back to TS3 clients.
Whoever wants to know why we took it offline can read this statement (on purpose not clickable). https://community.teamspeak.com/t/weblist-and-public-voice-server-down/37585/55
Notes for this thread
Feedback as per always is welcome in this thread . Issues that are not related to this update belong to it’s own thread.
We suggest to place your wishes for upcoming releases in existing or new threads in the suggestion area instead of the release thread. We mention this because each update post will be closed after some days and the wish or suggestion could be lost.
We allow ourselves to delete all the off-topic posts from this thread.
Thank you, but the Master password error I had with the beta has now become worse for me (since downgrading to 3.5.6 does not help as a workaround anymore). Any help would be appreciated.
The current update is broken. I tried to log into multiple servers and it isnt working. It crashes as soon as I try to log into a server. i know of a few other people who are having the same problem. can I roll back?
Evry time I start to open my ts3 client this error pop out. I try to reinstall again ts3 and its the same problem. If somone know what is happening pls help me…
Also crashes on Mac OS X (13.4) on startup or is loading forever (App not responding). Reverted back to 3.5.7 Beta as this is the only functioning version of TS3 on Mac OS X. 3.5.6 on Mac OS X is crashing on connecting to servers.
