TeamSpeak 3 Client 3.6.2
A new beta was released :loudspeaker:
A critical crash was fixed. That’s why we released this version earlier than planned.
  • This client also does fix the issue where Asus sound cards changed their settings.
  • We are working on the other audio issues (AGC, user make loud noise and chirping noise) and will release another 3.6.x for these.
=== Client Release 3.6.2 - 21 Sep 2023
* Fix Asus PCIe cards issue
* Fix a client crash
Notes for this thread
  • Feedback as per always is welcome in this thread :slight_smile:. Issues that are not related to this update belong to it’s own thread.
  • We suggest to place your wishes for upcoming releases in existing or new threads in the suggestion area instead of the release thread. We mention this because each update post will be closed after some days and the wish or suggestion could be lost.
  • We allow ourselves to delete all the off-topic posts from this thread.
Could not unpack
‘C:/Users/User/AppData/Local/Temp/teamspeak_temp_0/D3Dcompiler_47.dll.lzma2’ to
‘C:/Program Files/TeamSpeak 3 Client/D3Dcompiler_47.dll’
Could not unpack
‘C:/Users/User/AppData/Local/Temp/teamspeak_temp_0/Qt5Core.dll.lzma2’ to
‘C:/Program Files/TeamSpeak 3 Client/Qt5Core.dll’
rolling back file updates
Unfortunately this doesn’t tell much and worked here today. Wich Windows version is this happening on?
Will recheck, when back at my computer.
You can use the installer instead if you like.
http://files.teamspeak-services.com/releases/client/3.6.2/index.html
Installer worked fine, thx.
Windows 11 same error with updater and with installer I get this one
Screenshot 2023-09-21 211106
Resolved with a windows restart
In most cases the program (process) is still running and accessing files and then writing to these is forbidden.
teamspeak homepage is still providing 3.6.1 instead of 3.6.2
I also have an update problem.
I’m on Windows 10.
Here are the logs of the update failure:
Previous update session for v. 1695203293 found
Starting update process for client
Download / check product ini
Downloading ts3_client_win64.ini.lzma2
Downloading ts3_client_win64.ini.lzma2 finished
Downloading ts3_client_win64.ini.sig
Downloading ts3_client_win64.ini.sig finished
RSA check: true
Compiling download and replace list for client
Downloading files
Downloading bin_win64/D3Dcompiler_47.dll.lzma2
Downloading bin_win64/Qt5Positioning.dll.lzma2
Downloading bin_win64/Qt5PrintSupport.dll.lzma2
Downloading bin_win64/Qt5Qml.dll.lzma2
Downloading bin_win64/Qt5QmlModels.dll.lzma2
Downloading bin_win64/Qt5Quick.dll.lzma2
Downloading bin_win64/D3Dcompiler_47.dll.lzma2 finished
Downloading bin_win64/Qt5Positioning.dll.lzma2 finished
Downloading bin_win64/Qt5QuickWidgets.dll.lzma2
Downloading bin_win64/Qt5PrintSupport.dll.lzma2 finished
Downloading bin_win64/Qt5QmlModels.dll.lzma2 finished
Downloading bin_win64/Qt5Quick.dll.lzma2 finished
Downloading bin_win64/Qt5Sql.dll.lzma2
Downloading bin_win64/Qt5QuickWidgets.dll.lzma2 finished
Downloading bin_win64/Qt5Svg.dll.lzma2
Downloading bin_win64/Qt5WebChannel.dll.lzma2
Downloading bin_win64/Qt5WebEngineCore.dll.lzma2
Downloading bin_win64/Qt5WebEngineWidgets.dll.lzma2
Downloading bin_win64/Qt5Sql.dll.lzma2 finished
Downloading bin_win64/Qt5WebSockets.dll.lzma2
Downloading bin_win64/Qt5WebChannel.dll.lzma2 finished
Downloading bin_win64/Qt5Svg.dll.lzma2 finished
Downloading bin_win64/Qt5WebEngineWidgets.dll.lzma2 finished
Downloading bin_win64/QtWebEngineProcess.exe.lzma2
Downloading bin_win64/changelog.txt.lzma2
Downloading bin_win64/Qt5Qml.dll.lzma2 finished
Downloading bin_win64/createfileassoc.exe.lzma2
Downloading bin_win64/Qt5WebSockets.dll.lzma2 finished
Downloading bin_win64/QtWebEngineProcess.exe.lzma2 finished
Downloading bin_win64/error_report.exe.lzma2
Downloading bin_win64/libEGL.dll.lzma2
Downloading bin_win64/createfileassoc.exe.lzma2 finished
Downloading bin_win64/libGLESv2.dll.lzma2
Downloading bin_win64/changelog.txt.lzma2 finished
Downloading bin_win64/libcrypto-1_1-x64.dll.lzma2
Downloading bin_win64/libssl-1_1-x64.dll.lzma2
Downloading bin_win64/error_report.exe.lzma2 finished
Downloading bin_win64/libEGL.dll.lzma2 finished
Downloading bin_win64/opengl32sw.dll.lzma2
Downloading bin_win64/package_inst.exe.lzma2
Downloading bin_win64/libssl-1_1-x64.dll.lzma2 finished
Downloading bin_win64/quazip.dll.lzma2
Downloading bin_win64/libGLESv2.dll.lzma2 finished
Downloading bin_win64/soundbackends/directsound_win64.dll.lzma2
Downloading bin_win64/package_inst.exe.lzma2 finished
Downloading bin_win64/quazip.dll.lzma2 finished
Downloading bin_win64/ts3client_win64.exe.lzma2
Downloading bin_win64/soundbackends/directsound_win64.dll.lzma2 finished
Downloading bin_win64/Qt5WebEngineCore.dll.lzma2 finished
Downloading bin_win64/opengl32sw.dll.lzma2 finished
Downloading bin_win64/libcrypto-1_1-x64.dll.lzma2 finished
Downloading bin_win64/ts3client_win64.exe.lzma2 finished
Starting file updates
add/replace D3Dcompiler_47.dll.lzma2
add/replace Qt5Core.dll.lzma2
Could not unpack ‘C:/Users/Mamouthe/AppData/Local/Temp/teamspeak_temp_0/Qt5Core.dll.lzma2’ to ‘C:/Users/Mamouthe/AppData/Local/TeamSpeak 3 Client/Qt5Core.dll’
Mise à jour annulée
The latest version avaible to download is 3.6.1, but in reality it is 3.6.2.
imagen
If you really need the latest installer, then you can get it here.
https://files.teamspeak-services.com/releases/client/3.6.2/index.html
