I can’t find the room icon settings anywhere, or It was not? It’s very frustrating that the room icons are at a stupid angle, they don’t look right.
I’ve noticed a problem since this update. On the dashboard the “My Server” section on the left is missing so I cannot find and connect to the free TS server there.
Only way I can connect to it is in the recent connections on the main dashboard screen. If I was to accidentally clear the recent connections on the dashboard I don’t see how I would connect to the server then. Also when I click on the file menu everything is greyed out bar the settings as seen in the 2nd image.
is it intended that i only can join with ts3 client on the free server?
ts5 beta 31 cant even see or join it. or is there a way to join free server with ts5 beta if it is not in recent list? otherwise i would have to use ts3 again
The free server have been temporarily closed as staff team mentioned. They will open again in later time.
As about the joining options, after client version 3.5.3 you are able to join the test servers.
As @Alligatoras said, they are shutting down the servers, presumably only temporarily, and thus disabled the option to see it in TS5.
You still can see it in TS3 as they can not quickly disable your bookmarks partially.
You only can still connect via TS3 as they didn’t shut the server down yet.
They probably didn’t expect beta users to still use TS3…
