We pushed a new beta version into the closed beta channel.
This client adds a new overlay for pinned messages and will replace the old one in one of the next versions.
And we improved the UI with all the different scaling modes and touched the Detailed Server Tree to save a bit more space.
We know you are waiting for it but Whisperlists did not make into this version but we are working on it to bring it in one of the next updates.
* New pinned message view
* Adjust UI scaling modes
* Adjust detailed tree sizing
* Fix missing kick information when kicked for idle time
* Fix still sharing servers after restarting the client
* Various bug fixes and improvements
Known:
- Pinned message fade out animation after you minimized them and re select the chat
- If there is only one pinned message then you can not delete it in the overlay (you must use the old pinned message dialog)
Notes for this thread
- Feedback for this release is always welcome
- We suggest to place wishes for upcoming releases in existing or new threads in the suggestion area instead of the release thread. This one will be closed after some days and the wish or suggestion will be lost.
- We allow ourself to delete all the off-topic posts from this thread.
