Maximal compatibility version is 10.15.7 (Catalina) for me. If i try install bigger version, i get error with compatibility.
A post was merged into an existing topic: TS5-Window not fully maximized
Just another thought after one user reported the same.
Is the client snapped on the left side on the monitor?
In case it is this is known. The client will restart with default size when last position was snapped in Windows.
Yes I know what you mean but no, I donât use windows snapping for that, I set the dimensions manually leaving few pixels of margin on each side
after yesterdayâs discussion in the german Beta Test room and several users of my own TS approaching me that they are unable to create a chat account even with âmultipassâ activated, I decided to create several fresh myTS accounts to test.
I was unable to set my homebase to either central or decentral with those freshly created myTS accounts and also the tschat.log stayed empty even with âdebugâ log level (multipass was ofc activated). After downgrading to beta70, I was able to set homebase to central on those same accounts. If you need more details, feel free to ask me
Kind regards.
Danke!
We can reproduce this and will investigate.
We still struggle to reproduce this here.
Is this also happening while client was closed on Main screen?
Is there any software (other then Windows or your Driver) involved for multi monitor usage?
And by any chance is this active?
Canât disable TeamSpeak TourâŚ
This Slider moved to left side is supposed to start tour again and next time you open option the tour was started and slider was also moved to right again.
Short itâs a Reset Tour button
I donât understand, doesnât really make sense.
Why then a slide button and no push button?
You disable the option and thus tell the client that you have not yet seen the tour. So directly after that the client starts the tour again. When the tour started the toggle button getâs activated again as you now have seen the tour.
Best would be a link a âReset Tourâ
Not a button or a slider.
I agree with you.
Actually no⌠this does not happen on my main screen. I do have DMT software installed so I can lock out my mouse leaving the screen if I play a game in a window mode but itâs turned off and I havenât used it for some time now. One interesting thing I discovered is that what actually happens is that each time the client start up on that specific screen it grows by itself which is bizarre so actually the problem is not that it doesnât store last set dimensions but that it grows with each restart and it can grow infinitely. Check out the vid I recorded with screens side by side.
I will do some more digging
//edit
I found it, I took a screenshot before I closed down the client and then I took one after and noticed itâs about 25% bigger and each restart grows it by another 25% which got me thinking and I figured it out, itâs the Windows scaling, on that monitor itâs set to 125% so I can see better
while the rest is original 100%. Tested it on my main where I set 125% and the problem occurs you can now try it out yourself.
Hello ! i am new here, when i try to press on the "Setup chatâ buton then âUse MyTSâ, there is an error saying Unable to set Homebase. anyone know what im doing wrong ?
i have the âTestâ Badge activated.
Download the installer from website and set your homebase.
Then restart client to get the update to beta 71.
hey
since the latest patch 71 for teamspeak 5, teamspeak 5 closes randomly without an error or an error tone.
windows 11
i have upload 2 logs maybe it helps
With a chance of 50% Itâs your mouse.
We are aware of that bug.
Meanwhile killing the hotkey helper process in task manger helps.
What I need to get [email protected] account name for all features of TS5?
I have account with these features, but my friend hasnât.
He has âSetup Chatâ button and there are nothing works.
Select MyTS as your Homebase - Use MyTS => Unable to set Homebase [Error: object Object
Did you redeem the badge code MULTIPASS? Afterwards you will receive the Test badge and have access to global messaging services.
