I have gone through every scrap of info on the forums to figure out why TS5 simply wont open.
I get NO error message or anything. It’s like I have not even tried to open it.
I have tried resetting %appdata%, running as admin and everything else.
It works fine on another system from the same install.msi and works fine on a temp created user account on this system but DOES NOT work on my main account.
Farming this one out to you all as I’m about ready to punch my screen right now.
Ok so this has just now happened. I uninstalled TS5, installed 5.0.0-beta29.1 again then did not open it and installed the latest version of TS5 on top of the old install, thus bypassing the built-in updater.
It could be that another program does block the dll or the dll is broken.
You could try to install the client into another location (which is not C:\Program Files or C:\Program Files (x86))
Ok I have copied the working install from another system to this one and we’re now back to me trying to open TS5 and getting no error and no program starting.
did you make a clean uninstall:
deinstall over the uninstaller, make sure that everything is deinstalled
(Default: C:\Program Files\TeamSpeak)
delet all appdata files:
Default: C:\Users%USERNAME%\AppData\Roaming\TeamSpeak and
Default: C:\Users%USERNAME%\AppData\Local\TeamSpeak
