I recently decided to remove my two old hard drives that were in raid 0 by a software after detecting issues on them. So after I removed them while my computer was shut down I started it and tried normally to start TeamSpeak 5 to go talk with friends but now starts the issue. It doesn’t open anymore, just like yesterday it started.
I tried a few following things.
uninstalled TeamSpeak 5 from Apps & Features sections
Confirmed that all the files from %appdata% and %localappdata% dedicated to TeamSpeak 5 were deleted.
Went into TeamSpeak website, logged in and started downloading TeamSpeak 5.0.0-beta75
installed the new version and installation finished according to installer and event viewer.
Tried to open just installed TeamSpeak 5 and it didn’t even open it.
Went to logs and confirmed that log files were all empty. No more information on event viewer, either.
Tried these steps few times until I gave up and tried to test if HDD have any effect on the case.
Installed old hard drives back to computer and voilà, TeamSpeak 5 opens just like yesterday.
So the question is why does HDD have such a big role for TeamSpeak?
Also, a thing to point out, there is no TeamSpeak on those two HDD. Only few folders for pictures and few games.
I have tried everything to get this thing back to work, but I have run all the ideas with no luck.
So I am not going to be able to use Teamspeak anymore because two Seagate hard drives both failed and chances to get them fixed without losing any data is basically zero.
Great software if you can only install it to current setup and any broken parts will just make it brick in TeamSpeak part.
Here is all my logs that i get
[0918/182732.530:INFO:crash_reporting.cc(211)] Crash reporting enabled for process: browser
[0918/182733.227:INFO:crash_reporting.cc(211)] Crash reporting enabled for process: browser
[0918/182733.926:INFO:crash_reporting.cc(211)] Crash reporting enabled for process: browser
[0918/182734.288:INFO:crash_reporting.cc(211)] Crash reporting enabled for process: browser
[0918/182734.635:INFO:crash_reporting.cc(211)] Crash reporting enabled for process: browser
[0918/182735.001:INFO:crash_reporting.cc(211)] Crash reporting enabled for process: browser
[0918/182735.341:INFO:crash_reporting.cc(211)] Crash reporting enabled for process: browser
[0918/182735.704:INFO:crash_reporting.cc(211)] Crash reporting enabled for process: browser
[0918/182736.108:INFO:crash_reporting.cc(211)] Crash reporting enabled for process: browser
[0918/182736.670:INFO:crash_reporting.cc(211)] Crash reporting enabled for process: browser
[0918/182737.042:INFO:crash_reporting.cc(211)] Crash reporting enabled for process: browser
[0918/182737.774:INFO:crash_reporting.cc(211)] Crash reporting enabled for process: browser
[0918/182738.442:INFO:crash_reporting.cc(211)] Crash reporting enabled for process: browser
[0918/182739.103:INFO:crash_reporting.cc(211)] Crash reporting enabled for process: browser
[0918/182739.776:INFO:crash_reporting.cc(211)] Crash reporting enabled for process: browser
[0918/182740.558:INFO:crash_reporting.cc(211)] Crash reporting enabled for process: browser
[0918/182741.285:INFO:crash_reporting.cc(211)] Crash reporting enabled for process: browser
[0918/182802.617:INFO:crash_reporting.cc(211)] Crash reporting enabled for process: browser
