TS client crashes on MacOS when connecting
Thank you…problem fixed
Cheers
Hello folks,
I am dealing with this problem for a while now already.
The TS3-Client on my Mac-Laptop is always closing itself instantly when I try to join any server.
I am using the 11.6.1 macOS Big Sur version and the TS-Version 3.5.6.
I already tried to restart the Mac, reinstall TS and restart TS multiple times.
There is no Error-Code and this is what I get in my console system-logs:
ts3client_mac[63745]: getattrlist failed for /System/Library/Extensions/AppleIntelKBLGraphicsGLDriver.bundle/Contents/MacOS/AppleIntelKBLGraphicsGLDriver: #2: No such file or directory
ts3client_mac[63745]: getattrlist failed for /System/Library/Frameworks/OpenGL.framework/Resources//GLRendererFloat.bundle/GLRendererFloat: #2: No such file or directory
it would be awesome if anyone could help me.
Wishing you all a good start into the new year :D
Have a look at this version of TeamSpeak: http://files.teamspeak-services.com/pre_releases/client/3.5.7-beta.1/TeamSpeak3-Client-macosx-3.5.7.dmg
There is a problem with mac version forum thread. Download the 3.5.7 version
Thank you, you two
Using the 3.5.7 version helped - If I knew this version was already available… well still - Thank you :smiley:
moved by moderator
Please optimise TS3 with M1 or rosetta
when I try to connect TeamSpeak on a MAC, it crashes right after I hit Connect?
Anyone knows this problem?
Thanks,
Claudio
This Version fixes the crash: http://files.teamspeak-services.com/pre_releases/client/3.5.7-beta.1/TeamSpeak3-Client-macosx-3.5.7.dmg
That fixed the problem. Thanks a lot
moved by moderator
Hey! I’ve tried to download TeamSpeak for Mac (I have the macOS Monterey) and it is not working. I’ve tried the newest version and a lot of old versions just to check. Help would be great, as all my friends are on TeamSpeak :-)
Can you please post your Client log. :)
What type of error r u facing with?
Hi I’ve got MacBook M1 and i wanted to use TeamSpeak but it has a problem with connection. Whenever I try to connect to server TS app just closes without any info. Any one got any idea?
When I join a server it closes immediately (crashes). I have no plugins installed and am on the Mac M1 ARM chip. Help would be appreciated :)
Please try this TeamSpeak Version, this may fix the crash, that you have.
You need to use this version: http://files.teamspeak-services.com/pre_releases/client/3.5.7-beta.1/TeamSpeak3-Client-macosx-3.5.7.dmg
TS crashes on Monterey 12.2.1
