Ts3 3.6.0 addons incompatible
If anyone (like me) is using CrossVR’s logitech G-key plugin it’s now incompatible.
I’ve forked his repo for the plugin, updated it and created a pull request for new API version, but until He will accept that PR You can use release from my fork to continue using the plugin with 3.6.0: Release v1.2 · KombatPL/gkey_plugin · GitHub
Also it would be awesome to get updated plugin for the G15 keyboard LCD (yes there are people using it in 2023), or at least point me to it’s source code - I’d try to update it myself.
Yeah i need it to
do we know when this is going to be updated by TeamSpeak Systems GmbH
What for Plugins?
If you mean the Control Plugin and the Client Query plugin then please open the following Link:
https://drive.google.com/file/d/1X4BX0lFxPg_pyBMX_S65AwCm-Vfqx1kr/view
Yeah not sure if the plugins can update until this TeamSpeak-Systems/ts3client-pluginsdk: TeamSpeak 3 Client Plugin SDK (github.com) is updated
Yes, they can. Even though the client plugin SDK was not updated since version 24, plugin authors only need to change the Qt version they compile against to the newest one used by the TS client. And ofc they need to set the API version to 26 to indicate the update.
oh tyvm I wasn’t sure if just changing Qt and version would work
Also is it me or the chatbox is a bit broken cause it keeps replacing my chat with Enter Chat Message text
In case u manage to update the G15/19 Plugin pls let me know. YES, the best keyboard ever is still in use and the interaction it allowed was amazing :smiley: Hope to get back the possibility to perform actions in TS3 without buying a 2nd monitor or switching out of any game soon!
This is one of the most botched releases I’ve seen so far in my history with teamspeak… You did not even update your own plug-ins before releasing 3.6.0?
When will the versions for all the plug-ins by TeamSpeakSystems GmbH be available? E.g. LUA, ClientQuery, etc.
so i play fivem as a cop and we use TeamSpeak for our radio and my PTT is on my controller ive tried to uninstall the plugin multiple times and for some reason it says its not compatible 23 out of 26 or something like that im just wondering if im doing anything wrong if somebody could please help that would be awesome
Then please contact the Plugin Author that He must update his Plugin to API Version 26.
When you say Control Plugin, then please download the updated Version here:
it wont let me download any of those files it just says copy file name
never mind i figured it out thank you so much for your help
How did you fix it? I’m having the same problem
You mean with the Control Plugin?
yepp updateing Client Query and Gamepad Controlls worked just fine.
I hope they will look out for this in the upcoming patches
A bunch of my friends and I discovered rather abruptly that our programmed HOTAS “push-to-talk” configurations were completely blown away when updating to 3.6. We have many types of controllers and the only key bindings that work are the keyboard and the mouse. NO onther usb controller of any type works! It also destroyed all the whisper commands linked to HOTAS buttons.
There was no warning. This is totally unacceptable behavior from a software company which up,till this point was trusted across the entire gaming community. Thankfully, many of us were able to reinstall a 3.5 version. Still, this is just wrong and needs to corrected asap.
20+ year User
I’m also experiencing this problem and it makes TS effectively useless. Hoping for a Hotfix very soon or will have to use another service (SRS, etc.)
Update with this files. Streamdeck and Josticks are working for me again
https://drive.google.com/file/d/1X4BX0lFxPg_pyBMX_S65AwCm-Vfqx1kr/view?usp=drive_link
Hello friends,
Why since the last update I can no longer trigger my microphone with the right button of my Yoke Saitek? It’s very inconvenient for me, I need my mouse for something else and I want to keep my keyboard shortcuts
I have exactly the same problem and it effectively means that I cannot use TS. Hopefully there is a Hotfix for this coming very soon or I will have to consider alternatives.
