Ts3 3.6.0 addons incompatible
thank you!
I made a 64 bit installer for our own plugins for client 3.6.0 (Windows)
One would expect for TS to have their own plugins updated when they release a new version, but I guess not.
Thanks @TS.ChrisR, ClientQuery works again
Thanks for that, mine is working again too
Thanks in resolved most of my problems but i still cant use my Soundboard in plugins
Capture d’écran (42)
The plugin author needs to update the plugin in order for it to work again
oh ok We need to tell Marius Grafe !
he created the plugin :joy:
TeamSpeak has been great for roleplay. How can I update things like RadioFX?
Unfortunately your Update broke nearly all Plugins. The most important one, the Streamdeck Extensions doesn’t work with the API anymore, and the maker of it isn’t updating it soon probably, what sucks huuugely.
Im sorry, but I think you an hear my frustration thru this small topic.
all the best
If you don’t need any TeamSpeak 3 features you could switch to TeamSpeak 5 and use my Stream Deck Plugin.
Edit: the plugin should work again if the Query Client gets updated by TeamSpeak
Hi Leon, first of al thanks your fast Reply. TS5 is not an option because the whole game Organisation is declares TS3 as mainComm platform.
One of our guys which built a custom TS Radio offered to program a new Plugin for a beer.
Any idea when the plugin api repo will be updated?
idk
Good Morning @Checkedsauce7 ,
Please take have a look into this Thread:
The Plugin Author must update his Plugin to API Version 26
But if you want to get back to the Old Version (3.5.6) then please do the following:
Streamdeck Plugin doesn’t work anymore, ClientQuery by ZerGo0
very sad , an according to Downloads highly used .
The update broke my addons I have tried to uninstall and reinstall them but it didn’t work.
The Plugin Author needs to update his Plugin to API Version 26
If you want to downgrade your Client to the Old Version back then,
Please use the following link to download the previous TeamSpeak 3 client version :
http://files.teamspeak-services.com/releases/client/3.5.6/
Edit: I see you have the Control Plugin. Here is an updated Version:
https://drive.google.com/file/d/1X4BX0lFxPg_pyBMX_S65AwCm-Vfqx1kr/view
What the hell is a c++? I have never heard of that. But I can give you the igsact error code that ts is giving us after you guys updated it…
Plugin failed to load: Api version is not compatible: 23 (minimum: 26, current: 25)
That is what it is giving us when we try to use our plugins. And I use my teamspeak a lot this is not right there should be a way around this or a remediate fix or something!!!
The plugin you want to use must be updated from Plugin author or as an option you downgrade back to 3.5.6 as long this did not happen.
C++ is programming language for software developers.
