TS3 Client closes itself
Hello. It started about a week ago. Whenever I start the TS3 client, it freezes briefly and then the client simply closes itself. No error message, nothing. I’m unable to connect to any server. It usually takes several attempts before I get lucky.
I’ve reinstalled TS several times and removed all legacy files before reinstalling. I also started the program in admin mode, but the problem still persists.
I’ve been using TS for years and have never had any problems like this. TS is also NOT blocked by the firewall or anything like that.
The only add-ons I’ve installed are YACA (which I need for my GTA V RP server) and the RP Soundboard. But I’ve been using both of them longer than this problem existed.
I’m really at my wit’s end and don’t know what to do next.
Can anyone help me?
Thanks in advance.
Please try to start the client in safemode:
Nope. Even with the -safemode. When I double Click it. It opens and close after a few Seconds. :sweat_smile:
In the post I have linked you’ll find a section for crash dumps. Please attach one to further investigate this issue.
My Folder for Crashdumps is empty :sweat_smile: Sadly there is no File.
Are any client logs created?
Appdata%\Roaming\TS3Client\Logs
This is the only Log the TS generated.
I was now able to connect after 5 Trys.
The client was not started with proper -safemode parameters as you can clearly see in the logs that the addons are being loaded.
I did with the -savemode. Didn’t changed a Thing. Added now the Screen from the current log now. Also added a Screenshot where u can see it contains the ‘-safemode’ :confused:
Wrong log sorry for that. Now its the correct log.
Can you try updating your client version to 3.6.2?
There is a client crash fix that could be responsible for your crash.
Here is a Changelog of the new Client Version:
=== Client Release 3.6.2 - 21 Sep 2023
  • Fix Asus PCIe cards issue
  • Fix a client crash
