I’m testing the new TS5 beta.
Everytime I connect any server, after some time (usually less than 1 minute) I start to see strange artifacts in the frontend, as you can see:
I’ve just see the workaround consisting in disabling sharpening in Nvidia control panel. After doing it’s working without visual artifacts, but I prefer sharpening for other apps, so I’ll deal with the problem until it get fixed (simply moving or resizing the TS window solves the problem for some minutes).
I wonder if you can enable/disable Sharpening with profiles, on application to application basis. This way you would be able to disable Sharpening only for TeamSpeak.
