TS5 Channel Image Generator Tool 🛠️🖼️
I am not 100% sure what you tried to say with that. The screenshot you provided is just how channel banners look. The tool perfectly reflects that.
If you do not like the aesthetics of those banners you could use my custom TeamSpeak Theme. It centers all banners.
https://community.teamspeak.com/t/skin-cleanspeak-a-the-all-new-teamspeak-5-theme/20168?u=gamer92000
They still do not get bigger in size though. They might only be more visible for channels where the name hides part of it.
sorry what I meant is you sen some people haw their picture go from one side of the channel to the other side off the Chanel bot when I putting it on I get it in a corner :sweat_smile:
If you make your TS window that small it will be from side to side.
The banners sadly have a fixed with at 400px.
aha that’s more understandable now I feel stupid
Great Idea :bulb:
Great tool man!
I :heart: it!
I was attempting to use the tool. Anytime I set the alignment for a subchannel, it doesn’t work. It always ends up a little too much to the left.
I was able to fix it. Thanks for the super cool tool!
@mickeylikecrazy I currently have the same problem with banners on sub channels.
Do you still know how you fixed it?
