Display country flag on clients. All new TeamSpeak is great idea,but it sure misses one thing that is FLAGS! i just can’t give up on clicking on clients and viewing their flags. Whos with me? @ts5 @idea
its okay, but why the code and syle and iconpack tag?
I would prefer some new country icons. Just to get rid of the old icons, which are implemented in the TS3 client. Take here an example.
do you need them that badly?
nice, new country icon for ts3 and ts5 client it would be great
in ts3 old country flag icon is little pixels for me , i think is old 16x16 resolution if they create new icons for ts5 they can replace in ts3 too
It has to be coded, and implemented from icon pack.
I need them that badly.
To be honest not only flags, and server icons too. If you open your phone client you see the server group icons pixeled too. My only solution to this issue was to add icons with 20x20 resolution and everything looked great, except the flags
Yeah the server icons are also not good, if you use a resolution like 16x16 directly. I just used 128x128 which is under 8kb and it worked fine. Now there’s an high resolution on the phone.
Otherweise you can change the country flags by your own - so you replace the data, remove the old country flags and replace them simply.
That’s nice. Never thought about it to be honest.
we use 32x32 png icons on our server and its looks great on desktop and mobile client too
I agree with you
i think that will not fit to some of the flags, but i’am voting for any kind of flags
How do u see png icons on android client,
I dont see any server group icons on android except for the default server admin one?
i think for some reason you can’t download the icons.
maybe router settings or isp or something.
i see all icons on any server.
Could u help me here on this thread
If u can, thanks ![]()
16x16 is old resolution but it should work.
Try to join another server and check the icons appear or not.
I checked in another servers and found out its not an issue of icons
When I check client info, I cannot see any server groups apart from the default ones (Server admin, etc).
Yeah hat the same
