What can i do when i do not hear anything or can't talk
Please read following post carefully
Check if your system receives sound from microphone
you receive it, however I managed to fix everything! Thanks anyway!
Hey everyone,
I’ve had the problem for some time that nobody on the server can hear me anymore. I’ve tried everything so far but nothing has helped.
I hope someone can help me :slight_smile:
08.04.2022 19:10:25 ClientUI Info Lookup finished: ip=193.41.226.29 port=9017 query=latenightv.eu error=0
08.04.2022 19:10:25 ClientUI Info Resolve successful: 193.41.226.29:9017
08.04.2022 19:10:25 ClientUI Info Initiating connection: 193.41.226.29:9017
08.04.2022 19:10:25 Windows Audio Session Devel DeviceDeleteList::wait_for_deletes - enter - DeviceDeleteList
08.04.2022 19:10:25 Windows Audio Session Devel DeviceDeleteList::wait_for_deletes - leave - DeviceDeleteList
08.04.2022 19:10:25 Windows Audio Session Debug WAS::openDevice-enter - {0.0.0.00000000}.{7aeab7b2-3255-4c82-9df6-da0e13104ccd}
08.04.2022 19:10:25 Windows Audio Session Devel Mix Format: SRate:48000 Bitrate: 32 Channels: 2 - VoiceMeeter Input (VB-Audio VoiceMeeter VAIO)
08.04.2022 19:10:25 Windows Audio Session Devel Initializing with mix format. - VoiceMeeter Input (VB-Audio VoiceMeeter VAIO)
08.04.2022 19:10:25 Windows Audio Session Info Initialized with 2 channels in 32bit, 48kHz. - VoiceMeeter Input (VB-Audio VoiceMeeter VAIO)
08.04.2022 19:10:25 Windows Audio Session Devel WAS Buffer size: 1056 - VoiceMeeter Input (VB-Audio VoiceMeeter VAIO)
08.04.2022 19:10:25 Windows Audio Session Debug WAS::openDevice-leave - {0.0.0.00000000}.{7aeab7b2-3255-4c82-9df6-da0e13104ccd}
08.04.2022 19:10:25 Windows Audio Session Debug WAS::startDevice-enter - {0.0.0.00000000}.{7aeab7b2-3255-4c82-9df6-da0e13104ccd}
08.04.2022 19:10:25 Windows Audio Session Debug WAS::startDevice-leave - {0.0.0.00000000}.{7aeab7b2-3255-4c82-9df6-da0e13104ccd}
08.04.2022 19:10:25 Windows Audio Session Debug WAS::openDevice-enter - {0.0.1.00000000}.{94fe0899-fb83-415e-8a18-3d8004a1c363}
08.04.2022 19:10:25 Windows Audio Session Devel Mix Format: SRate:48000 Bitrate: 32 Channels: 1 - Mikrofon (Trust USB microphone)
08.04.2022 19:10:25 Windows Audio Session Devel Initializing with mix format. - Mikrofon (Trust USB microphone)
08.04.2022 19:10:25 Windows Audio Session Info Initialized with 1 channels in 32bit, 48kHz. - Mikrofon (Trust USB microphone)
08.04.2022 19:10:25 Windows Audio Session Devel WAS Buffer size: 1056 - Mikrofon (Trust USB microphone)
08.04.2022 19:10:25 Windows Audio Session Debug WAS::openDevice-leave - {0.0.1.00000000}.{94fe0899-fb83-415e-8a18-3d8004a1c363}
08.04.2022 19:10:25 Windows Audio Session Debug WAS::startDevice-enter - {0.0.1.00000000}.{94fe0899-fb83-415e-8a18-3d8004a1c363}
08.04.2022 19:10:25 Windows Audio Session Debug WAS::startDevice-leave - {0.0.1.00000000}.{94fe0899-fb83-415e-8a18-3d8004a1c363}
08.04.2022 19:10:25 Windows Audio Session Debug WAS::associateAECDevice-enter - {0.0.1.00000000}.{94fe0899-fb83-415e-8a18-3d8004a1c363}
08.04.2022 19:10:25 Windows Audio Session Debug WAS::associateAECDevice-leave - {0.0.1.00000000}.{94fe0899-fb83-415e-8a18-3d8004a1c363}
08.04.2022 19:10:25 Windows Audio Session Debug [Playback] Got 3 or more rendering spaces in same loop 480 1056 576 - VoiceMeeter Input (VB-Audio VoiceMeeter VAIO)
08.04.2022 19:10:25 Windows Audio Session Devel [Echo] IAudioClient::GetDevicePeriod - 10.000000ms - VoiceMeeter Input (VB-Audio VoiceMeeter VAIO)
08.04.2022 19:10:25 ClientUI Info Connect status: Connecting
08.04.2022 19:10:25 PktHandler Devel Puzzle solve time: 4
08.04.2022 19:10:25 ClientUI Info Connect status: Connected
08.04.2022 19:10:25 ClientUI Info Connect status: Establishing connection
08.04.2022 19:10:25 ClientUI Info Connect status: Connection established
08.04.2022 19:10:27 TSDNS Info TSDNS queried unsuccessfully 178.33.33.125:41144
08.04.2022 19:10:27 TSDNS Info No TSDNS found
I don’t quite know what problem you’re talking about, but…
Are you talking via voicemeter or via your normal mic as input at ts?
i talking via voicemeeter, but the problem is that it cant find ts
dns, a few days ago it worked everything fine
This TSDNS info is only for connection and as long you are connected to a server it is not a problem.
The client tries multiple ways to connect to a server.
Got it fix for my Clan but still don’t hear anything. I repaired my Razer Nari Ultimate headset and mic. And still no sound. I can hear in WoT ound and youtube vids but nothing in TS. any staff know what up?
Make sure, that you have selected the correct playback device.
If you have set up the profile correctly, please connect to your TeamSpeak server and also choose the correct playback profile.
playback_profile
TY that did it
As title says. I can hear playback test fine when i open ts3. when i join a server, i cant anyone or hear the playback test sound
Please take have a look into this Thread. :slight_smile:
Make sure that in Self → playback profile the correct profile is checked.
Have fixed it. Turns out it doesn’t like certain USB slots xD
So I can hear everyone in Teamspeak but they can’t hear me. When I do the audio test I can hear myself from my mic so I know that works but I can’t figure out why they can’t hear me
Your Post was moved to this Thread.
Please read the 1st Post. :slight_smile:
About 2 weeks ago I updated TS3 - the voice disappeared. Nobody hears me, I listen to everyone. Uninstalling the new version of TS, cleaning the registry and rolling back the driver to an older version did not lead to anything. Still no one can hear me. Manipulating the settings also led to nothing. I still have an old Win 32 Sp-1. Is it possible to install a working version and where can I download it?
Hey @_BORG_nobor and welcome to the Forum.
You can take a look at this Thread: What can i do when i do not hear anything or can't talk
moved by moderator
Hello everyone,
I have a problem with my new microphone. I bought a new Shure SM7DB and the Focusrite ScarlettSolo 4th Gen Mixer. I connected it normally and it works fine in Discord. However, when I join my own Teamspeak server, my microphone does not work. However, when I go into the options and start a microphone test, it works (screenshot). Do you have any idea what I can do?
Here are some screenshots:
Thank you for your help.
Regards
Kai
