As said
This is an process that happens automatically before a server was build.
So i assume this db was updated.
But i forward that to our developers to make sure if an update was applied.
Heya
From 3.1.1 Linux to 3.13.5 Linux dont fixed the wrong flag
inetnum: 5.252.179.0 - 5.252.179.255
geoloc: 55.652641 37.529029
country: RU
City Moscow
Coordinates of City 55.752220, 37.615560 (55°45ā8"N 37°36ā56"E)
IDD & Area Code (7) 0495
i get a Moldova flag, dunno why
on https://www.ip2location.com/demo all fine the flag with RU ( [Russian Federation]
Country information about Russian Federation [RU]
i hope u can fixed or can you give an instruction how to use the GeoIP from MAX, what exactly you have to do, e.g. which DB etc.?
cya
Xenya
Please take a Look here
i read that, did you also read my text ?
from 3.1.1 Linux to 3.13.5 Linux server version it was not fixed, and I think thatās quite a few versions in between or ?
TeamSpeak 3 3.1.1.1 released on January 15th, 2020 and TS3 Server 3.13.5 on 18 May 2021
Also since server release 3.13.0 9 November 2020
this is supported: New support for MMDB style GeoIP databases
But there is no exact instruction how to do this or which DB to use from MMDB.
cya
Xernya
Quoting the server_quickstart.md which can be foudn in the doc folder
- mmdbpath (empty)
Set to the path of an MMDB file to use this as a source for GeoIP lookups. Requires libmaxminddb installed, which can be found in most Linux distributions as a package. Windows users can use the .dll found in the redist folder.
Heya
no i mean which DB, csv etc ( country, city )
cya
Xenya
The DB you downloaded from MaxMind.
You can use all their DB types.
Heya
ok i wanna try this on the ts3.ini file with mmdbpath=geoip/geo.mmdb
from GeoLite2-Country_20210601
cya
Xenya
Heya
works perfect with this DB, all fine now
start the server with ./ts3server_startscript.sh start inifile=ts3server.ini
logfile: 2021-06-07 13:13:36.632316|INFO |GeoIP | |mmdb database found and will be used for geoip lookups
cya
Xenya
Hi, I need some help, a flag of my country doesnāt appear next to my name on TS3, could someone help me, Iāve already been banned because of that I would like to solve
Sometimes there are gaps in the geo-location data. Are you using a VPN ore somethins witch blocks you geo-location? I had that same problem once and a serverupdate fixed it for me.
Do you have this porblem on every teamspeak server ore just one?
And just a tip this is an englisch forum so please you englisch next time
Iām having this problem on every server I log on!
I know people who only got an IPv6 address from their provider.
I could imagine that your provider only gives you an IPv6 address too and that this address is not on the hardcoded geo ip list which is integrated in the ts3 server.
This list is not up to date, thatās why ts3 servers have the possibility to use external lists.
Check on one of the whats-my-ip-address websites (e.g. https://whatismyipaddress.com/) if your provider only gives you only an IPv6 address or an IPv4 too.
I could imagine that this is the problem.
I just checked the site you gave me, it only detected ipv4, ipv6 didnāt!
Did the website detected your location correctly (at least country)?
yes detected the country correctly!
Can you please read post 3 in this thread? It explains why your flag is wrong/not recognized.
Just as Iāve mentioned it quite a year agoā¦
- Check your IP address under www.ip2location.com
- Contact the IP2Location support, when itās wrong. ā E-Mail: support@ip2location.com
- Wait until the next month or server update for the fresh database ā or you can also download the latest IP2LOC DB and use it for your server.
You can also use a IP address location database from another provider, e.g. MaxMind or anything else.
Have fun while suffering. ![]()
I WOULD REALLY YOU TO FIX THIS ASAP AS MY COUNTRY FLAG IS WRONG ON THE CURRENT SERVER I AM ON IT IS SHOWING THAT I AM FROM INDIA WHEN I LIVE IN THE UNITED KINGDOM AND I DO NOT USE A VPN OR ANYTHING. I AM AM ON 3.5.6 STABLE VERSION OF TS.
IT ONLY HAPPENS ON ONE SERVER THAT I HAVE TO GO ON
Attachment(s)
