Alpha Testing?
1. Overall, how long have you used TeamSpeak for? (any version)
I started using teamspeak in my dark orbit-phase back in 2008.
2. What OS/OS’s are you currently using?
Mainly i use windows 10. I also love using linux (pop_OS, Ubuntu, Debian) on other devices
3. Are you currently a server owner, an active user (but don’t run your own server), inactive, or a mixture of the prior?
I’m currently an active server owner with a NPL since 2016 also testing the newest betas if they get announced in this forum :slight_smile:
4. On a scale of 1-5 (1 being low and 5 being the best), how would you score your technical knowledge on TS?
I would say it’s something like a 4. I don’t know everything but i solved many problems for users on my server.
5. Optional question - If you could add something that doesn’t exist on TS currently, what would it be and why?
Bot integrations, like system bots which helps new server owners how to get their server secure without installing it from third-partys.
Since 2016
I’m using Windows 10 Pro.
I was a server owner & an active user 2 years ago on a gaming community, now i usually open teamspeak to speak with some old friends, but if i’ll be accepted as an alpha tester i’ll be active again.
My technical knowledge on TS is 3.
I would also like to apply for alpha testing.
About 3 - 4 years
Windows 10, Linux Kubuntu 20.04.02 LTS, Android 11
I run a small server for me and my friends.
Server side probably 2, maybe 3. I can setup a TS3 server with some permissions and channels.
Client side 3 - 4. Setting up a client is no problem.
I would add the possibility to drop files in a channel chat. And a seperate permissions to control this function based on server groups.
  1. TeamSpeak 3.1.10 March 10th 2019
  2. Windows 10, Linux Ubuntu 20.04
  3. Server Owner
  4. Techical knowledge - 4
  5. Send an Images to channel chat
Over 4 years give or take
Windows 10 / Arco-Linux
Server owner for me and some close friends
3-4 for both client and server side setup
since 2014.
  1. What OS/OS’s are you currently using?
Windows 10 and Android.
  1. Are you currently a server owner, an active user (but don’t run your own server), inactive, or a mixture of the prior?
server owner and active user, playing games with my boys :slight_smile:
  1. On a scale of 1-5 (1 being low and 5 being the best), how would you score your technical knowledge on TS?
  1. Optional question - If you could add something that doesn’t exist on TS currently, what would it be and why?
screen sharing
    I have not used teamspeak much at all, and I have only used TeamSpeak 3.
    Arch Linux is my main OS but i have Windows 10 installed on a seperate drive. I have a phone that runs Android 11.
    I am a inactive user, and I do have a TeamSpeak server hosted, and was planning to use it once I had access to TeamSpeak 5.
    Screensharing, as all of my friends will only switch to a program that has screensharing capabilities.
  1. Since 2015
  2. Windows but already used with Linux
  3. Not anymore an owner but i still use teamspeak because of the instable discord servers lol
4.5 i guess, already used query server and more
  1. Better image and multimedia sharing and screen sharing
I use TeamSpeak since 2014
I’m using Windows 10 Pro and Android .
An active user and I was an server owner long ago.
A stable 4 I know all app 100% and permissions like 80%
More support for plugins like custom background for TS5 , custom fonts to see ,soundboard ,clownfish ,etc.
I would love to test a alpha version of teamspeak. I´m a systemadministrator from germany and i love to explore new ways to solve problems. Atm i don´t have anyone else who is using ts5 on my server, so i couldn´t try the newest server features. I mean i could install a server for that, but because i don´t need it atm i didn´t had a urge to do it now. If it´s needed for the alpha i can still do it…
Teamspeak 2 for a few hours and then is used TS3 since it was released. Oldest entry on my current server is 2015, but i reinstalled it a few times.
Windows 10
I own one TS3 Server on a rented windows 2019 root server and administrating the settings of a 2nd server.
I would say 3-4 there is always more to find out. Some depths you only see when you fall into it through a problem. “The more you know, the more you know you don’t know.”
For myself i used 2 plugins in teamspeak3 which i love to use. One is TTS whenever a User joins i get directly told their name, so that i don´t have to look on the gui if the user isn´t talking directly. The second plugin is mass mover, sometimes we need to split groups for different games or same game different team and its nice to unit both groups with 2 clicks instead of moving every single user after a round.
A thing which would be great is a channel with permament text messages for everyone, like little news and arrange dates with other users. Please don´t missunderstand me, i love it as a feature that the channels have a chat which only the current users can read and share with each other, but a single channel for this feature would be great.
A thing what i saw from my users would be screen sharing, i know it´s causing traffic and not the easiiest thing to do, but that is a thing why some people on my server used teamspeak for talking with the group and was in a private discord call so that they could share their screen. Everyone uses different software and don´t want to trust the software from the other side, to have a option which comes with the software they already use(teamspeak) can solve that. It don´t have to be build in, a simple plugin which starts a 2nd software would help them. Some stuff is hard to explain to someone with less technical knowledge, when you can show them what they should do or otherwise you can tell where they should click can fasten that process very much.
Best regards
darkdacil
  1. since 2015
  2. Windows 10
  3. server owner & active user
  4. 4
  5. screen sharing
Since 2015
Currently, I’m using windows.
I’m a server owner and an active user.
I think I would say 4.
  1. Overall, how long have you used TeamSpeak for? (any version) 2009
  2. What OS/OS’s are you currently using? Windows 10
  3. Are you currently a server owner, an active user (but don’t run your own server), inactive, or a mixture of the prior? I run the Beta servers on my laptop for testing
  4. On a scale of 1-5 (1 being low and 5 being the best), how would you score your technical knowledge on TS? 5
  5. Optional question - If you could add something that doesn’t exist on TS currently, what would it be and why? Web Interface for server admin
I have been using TeamSpeak for more than 4 years now.
I am currently using Windows 10 and Ubuntu 20.04 on my desktop and Debian 10 on my servers.
I am an active user of the TeamSpeak 3 and 5 Client.
I also own multiple TeamSpeak servers.
5, on the TeamSpeak 3 Client
4, on the TeamSpeak 5 Client
3, on the TeamSpeak Server
Definitely screen sharing and application integrations (for instance Spotify or Steam).
  • Since 2015
  • Android & Windows 10
  • Server owner & active user.
  • Have my own server, and use more permissions [3/5]
  • Screen sharing [it would also be useful for not using external platforms]
  • A thing which would be great is a channel with permament text messages for everyone, like little news and arrange dates with other users.
Started with TS2 in 2004 :slight_smile:
Windows 10/ MacOS
Mainly active user without my own server. However, I have had an own local server in the past.
Solid 3
Similar chat options like Discord is currently offering in their text chat.
I’d like to become an alpha tester :slight_smile:
  • for about 11 years I guess
  • I’m using Windows 10 and Android
  • I’m a daily user
  • I would say 3
  • I’m happy with the current TS :slight_smile:
I have use teamspeak since 2016
I’m using Windows 10 but I have 2 more PCs with Windows 8 and Linux
I’m a user and a server owner. I host the server with my secondary pc
I would say 3 and a half
Well the interface is obsolete In 2021 . I would add a chat system and the ability to create server more easily. I would add the ability to send photos and the ability to link channels with different webhooks and integration with other games
Hope you will choose me <3
  • Round about 10 years, nearly daily use since 2015
  • Windows 10 clientside, Linux server, sometimes Android app
  • Active ts user and self hosting a server with 64 client licence
  • 3.5 :wink:
  • Chat function with a permanent save system like slack, discord etc. This would help to coordinate teams - no matter if gaming or for work.
Teamspeak 3 since 2012, Teamspeak 5 beta for about 1 and a half years
Windows 10
Active user
Images/alternative video embedding (sites like streamable.com for short clips instead of only Youtube)
