If you have Admin Server Query, you can create a second virtual Server via YatQa its very easy. Login with your Admin Server Query Data and there you go.
I have managed to create a second server within it but how do I connect to it as I can only connect to the dafault one and I’m trying to make 2 so we can connect our URL to them.
thats what I have installed and created a second virutal server within it but idk what i’m doing. DO I need to have 2 files within the C drive for TS or does it all goo off the YatQA programme? Confused.
I can’t create screenshots for you rn, as I’m on linux.
In YaTQA under the servers tab you should be able so see both instances and whether they are running.
If both are and you still can not connect to the second one with the correct port check your firewall settings.
Create a SRV Record on your DNS that pointing to your TS Instance.
The Service Name is “_ts3” on this Record you can also specify the TS Instance Port.
