How do I get a new recovery key? // My Badges are not shown in client
Due to reinstalling Windows I lost my recovery key for TS. By deleting the key, it is rejecting my access to my Badges ever since. Is there a way to get access to my recovery key/the whole account.
Please take have a look here: How do I get a new recovery key? // My Badges are not shown in client
moved by moderator
I have a problem with my recovery in the ts and can request nine keys because I lost mine can someone please help me because I didn’t get a nine via the ts when I entered my password
You can only generate a new one in case you did not reset your password.
If you lost yours and did reset your password, then you must do a fallback.
Please open and read following post.
Hello everybody, after changing the password and reinstalling windows, the synchronization of my account does not work.
I can’t see BADGES, servers and bookmarks
I also constantly ask for a recovery code at startup, which was not required before and it does not exist at all.
Please help me get my old data back <3
Simple as it sounds tryed to log into my account with an old password didnt worked so ichanged it but now i cant get full acess to it anymore bc iam missing the key which got lost in the 10 years or more i didnt used it .
greetings
You can’t get back your recovery key as long you made no backup.
You must reset your account encryption (fallback).
Explained in post #2
Ever since i reset my password i cant use badges in TS anymore, how do i fix it?
Read following post. At the bottom it explains what to do.
where is fallback
copy thank you
all good now
As explained :thinking:
2 posts were merged into an existing topic: Badges isn’t showing to others on all servers
merged by moderator
unfortunately I have problems with myTeamspeak at the moment.
I tried to log in on my laptop, but unfortunately did not remember my password.
I then requested a new password and logged in.
Teamspeak told me that I should use a backup code.
This I then also wanted to create via my PC, but unfortunately it was not displayed.
So I restarted Teamspeak and tried again.
ALs also failed, I have then logged out and logged back into myTeamspeak.
Unfortunately all my identities were gone and also all my favorites.
This means that I currently have no rights on any server and have lost everything.
Is it possible to somehow get back to the backup?
I have also tried to set my Teamspeak as a favorite again, but as soon as I log out and log in again, the server is no longer available.
<13:28:37> The TeamSpeak server could not validate your myTeamSpeak ID. Not all myTeamSpeak services are available.
<13:28:37> Reconnect might solve the problem.
That show me Teamspeak when i connect to my server.
Can someone help me???
WFG
You are in that situation because you ignored all warnings in dialogs in the past :roll_eyes:
Please read following carefully.
hello impossible to save my identity and server it tells me about the encryption key that I do not have when I want to relink my teamspeak account a solution how to delete my teamspeak account THE SUPPOR sent me to this forum…
If you have the recovery key saved in a file from when you made your myTeamSpeak account you can use it and you can save your identity, if you don’t have it you can use the Fallback option.
This Fallback option will erase the information currently in your myTeamSpeak account but will allow you to use the same email address/account for further use.
Unfortunately this is the only course of action once you have lost your key.
hello how to do a complete reset to recreate a key ???
when I want to do it via the teamspeak client by clicking on new recovery key I enter my password as my request does not generate any key for me what to do??? thanks in advance
Arkana
Guess this happens in TS3?
What is in your client log (CTRL + L or Tools > Client log) ) when you tried it?
If this is in TS 5 the client log can be found in
%localappdata%\TeamSpeak\Logs\Default
