Either you are not logged in with the same account or you reset your password without the necessary recovery key. In this case all your stored bookmarks and identities will be gone and you won’t be able to access your badges too unless you make a new recovery key.
Hi, i made a new recovery key, but nothing happens…
18/02/2021 22:31:14 SyncImpl Info Successfully requested new backup key
Please post a Client Log
So when you got a new key , then you made a fallback and your bookmarks stay gone because the online content was deleted. There is no way to get them back from the account.
Badges stay.
No, i never did the fallback, and i’m using the same account, i don’t have a 2nd account.
and there’s not a badge or anything else, btw, when i try to recover the key, nothing happens
And you did not reset your password?
From the log it looks like you did because sync could not be initialized.
yes i did, but i use TS3 since there was not the myTeamSpeak client integration when there was the identity only, and i have the .ini file, and I have never seen the message about the recovery key.
i can login in to the client and in the dashboard, and yes, it’s the same account.
Then please read post 2 of this thread.
try logging out and logging in again
I tried it
then like this, uninstall teamspeak, but don’t delete the teamspeak data but just delete the TS program and reinstall and try logging in and see if it can
then you got bored of it, try it like I told you
If one account shows the icons in client then you can at least connect to our services.
My wild guess because we got no logs.
The account that does not show them in client had a password reset and you did not enter the recovery key yet or you did not make a fallback.
Hey i don´t see my Badges on the Website i see 16 but in the Client i dont see my Badges
Where i can find recovery key?
At the place where you copied it to, when the client told you to copy it.
There is no way to get a recovery key back in case you did not copy it or wrote it down.
