Licensing Problems
Hey could someone help me pls.
got problem to activate my old NPL license :slight_smile:
2020-03-06 15:20:10.304032|INFO |ServerLibPriv | |TeamSpeak 3 Server 3.11.0 (2020-01-13 08:12:37)
2020-03-06 15:20:10.304224|INFO |ServerLibPriv | |SystemInformation: Linux 4.19.0 #1 SMP Thu Jun 27 15:10:55 MSK 2019 x86_64 Binary: 64bit
2020-03-06 15:20:10.304256|WARNING |ServerLibPriv | |The system locale is set to “C” this can cause unexpected behavior. We advice you to repair your locale!
2020-03-06 15:20:10.304270|INFO |ServerLibPriv | |Using hardware aes
2020-03-06 15:20:10.311195|INFO |DatabaseQuery | |dbPlugin name: SQLite3 plugin, Version 3, ©TeamSpeak Systems GmbH
2020-03-06 15:20:10.311250|INFO |DatabaseQuery | |dbPlugin version: 3.11.1
2020-03-06 15:20:10.315704|INFO |DatabaseQuery | |checking database integrity (may take a while)
2020-03-06 15:20:10.395351|INFO |Accounting | |found old license, downloading new license
2020-03-06 15:20:10.448896|INFO | | |myTeamSpeak identifier revocation list was downloaded successfully - all related features are activated
2020-03-06 15:20:10.490003|ERROR |Accounting | |license is a legacy license
2020-03-06 15:20:10.491217|INFO |Accounting | |Licensing Information
2020-03-06 15:20:10.491254|INFO |Accounting | |licensed to : Anonymous
2020-03-06 15:20:10.491267|INFO |Accounting | |type : No License
2020-03-06 15:20:10.491282|INFO |Accounting | |starting date : Mon Jul 1 00:00:00 2019
2020-03-06 15:20:10.491293|INFO |Accounting | |ending date : Wed Jul 1 00:00:00 2020
2020-03-06 15:20:10.491303|INFO |Accounting | |max virtualservers: 1
2020-03-06 15:20:10.491313|INFO |Accounting | |max slots : 32
2020-03-06 15:20:12.043104|INFO | | |Puzzle precompute time: 1526
Where i can refresh my license?
Thx 4 help,
You can not refresh the NPL or request a new one.
It was important that you did use it in the past or it became invalid on “ending date”.
i use this in the past many gears, die last 2-4 years i dont know if i strat the server :slight_smile:now i got a new one and want to support my guild with a server.
discord is not my real friend, only one server by the time and some other shit :=)
so i start to install a server on my vps put the license.dat from the mail and it doesnt work :slight_smile:
ok what can i do now?
Just having used the license in the past is not enough.
I may used wrong words for what i meant to say. Let me retry.
It was important that you actively used the license or it became invalid on it’s “ending date” and did not renew then.
That is and was the only way to renew the NPL.
The NPL project was canceled a while ago.
There is no way to get outdated NPLs renewed or to get a new NPL.
What you can do now is to use the free license with 32 slots or get a license
or Sponsorship | TeamSpeak
the one in your email will not work only the one with theserver running will work
You can not use the old email license sine its old and expired you have to use one that had been updated from the server eg old server
