As mentioned in the post above, you should just create the file.
I donât see any possibility to create a user at https://translate.tmspk.net
That is correct, youâll need to wait until further Information get published.
Presumably later this week, as said in the Beta [DE] TS5 Group Chat, by a TeamSpeak Employee.
I would like to ask, after forcibly updating to beta75 under beta74, do the files that should exist under Roming appear on my computer desktop when running ts5? The file names that appear are DawnCache, GPUCache, debug.log, MediaDeviceSalts, and MediaDeviceSalts-journal. I hope the developers can provide explanations and solutions.
Thank you. I have read the discussion below the post and obtained the source. I hope to increase the release of beta76. It is recommended to create a custom language json setting. I donât really hope to suggest the actual meaning of the defined words on weblate. Again grateful!
I found a solution. You need to right-click the ts icon on the desktop and find the âStart Position (S)â column in the properties, and change the content after it to âC:\Program Files\TeamSpeakâ (my ts installation directory). When I opened it at first, it was âC:\Program Files\TeamSpeak\TeamSpeak.exeâ, which reminded me of running it repeatedly, so I modified it like this. When I start the ts client again, the prisonersâ files will not be generated on the desktop. . Your suggestion above has the same effect as I thought.
The picture below is what the icon generated on the desktop looks like after I installed beta75 (I am a Chinese, so it is in Chinese)
I was wondering where those files came from since they were not deletable, so i figured Iâd close TS5 and was able to delete them from my desktop. The joy was only shortwhile because as I restarted the TS5 client the files were created on my desktop again. Donât know if that is intended but could also not find a way to reconfigure the location. Thought I might share.
How do I get the Spanish language, this appears in that file {âapplication.ignore_exit_requestâ:true,âapplication.minimize_to_trayâ:true}
The Spanish Translation for the new TeamSpeak Client doesnât exist.
But if you want to contribute for the Community Translation, then please
read the Announcement Thread from Staff: TeamSpeak Community Translation
So how can I put it in English?
Itâs already explained here:
