Hey, after I start my teamspeak it isntantly crashes. I already reinstalled teamspeak, but it didnt help.
I am on Windows 10 2004.
here is my crashdump:
https://cdn.discordapp.com/attachments/791261371219312641/791261507983114240/ts3dump_1608721758957.zip
where should I put -safemode ?
It’s explained and shown in my post.
Can not add more since this is a step by step explanation already.
nevermind, thansk a lot. worked for me!
Hi Chris, sorry to bother you - I have the same problem that I cannot solve. Would you be able to have a look? Described in detail here together with crashdump (last post).
Hey
I see that this is a top issue after update now.
Is there any temporary solution?
Thanks in advance!
Sent: 16384/86968 bytes
Sent: 86968/86968 bytes
Error: 201
<?xml version="1.0" encoding="UTF-8"?>
AccessDenied
Invalid according to Policy: Policy expired.
4395C7093086E764
K0vRAIpwjcIOgD5XIl6RFaJPGwwlxLvT4RrBgjzsmzo0HJx/X4NeUwYExwyt/cq6ad/On+e66cU=
